Impact of Translation rules
techguy
Level 4
Level 4
Whats is impact of adding translation rule on following
voice-port 0/0/0:15
or
inbound dial-peer 1 pots
Chris Deren
The imapct is that matched numbers will be translated which is the idea.  Not much CPU overhead, etc if that is your concern.
HTH,
Chris
i mean to say whats the difference when configuring translation profile between voice-port and dial-peer
If you apply the translation to the voice-port, it applies to all calls traversing the port.
If you apply it to a dial-peer, it applies to all calls matching that peer.
Which is best depends on your scenario. If you have one E1, and want all calls treated the same... apply it on the port. If you want different translations depending on what has been dialled for outbound calls, apply translations on the dial-peers... etc etc.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
