Hi to all
at my client I have UCCE vers. 10.5 with Ip-Ivr 10.6
I have received a third party CA certificate with private key (.p12 file) because I must create un application that connects with a https web services.
I have created my java class, created keystore with private key, imported CA into truststore and everything is ok.
Then I have imported java class into IP-IVR's document.
With openssl I have create my file .pem to import inside Ip-IVR (Tomcat-trust) and everything seems ok.
But when I try to use my java custom class I always receive un error "remote host closed connection during handshake"
in this forum I have read that I cannot import private key.
"https://community.cisco.com/t5/ip-telephony-and-phones/cucm-export-tomcat-certificate-with-private-key/td-p/2773707"
=> This also means that you cannot use certs generated by a 3rd party as you cannot upload external certs with private key, which for example VCS does allow you to do. <=
I have imported other certificates without any problem.
Is this true ???
can anybody help me ?? if it is possible could someone explain me how to do it ???
thank you very much
Fabio
