Import/Export of CUCM configuration.
S Sadiq
How do we export the current cucm configuration(includign gateway,phone,UDP etc) for all the region in cluster
or do we have to export seperately phone, gateway etc.
Chris Deren
What are you trying to accomplish?
Are you migrating a location from one cluster to another?
Export/Import only works as long as CUCM versions are identical.  You do need to perform export/import of all settings you need (tick the checkboxes).
