05-18-2020 06:45 AM
Hello all of you. Is there any way to import the Translation Pattern from CUCM 8.62 to 11.5 for examble? Thanks in advance.
05-18-2020 07:03 AM
Yes with Bulk Export/Import. Possibly you'd might need to modify the export file from 8.x to fit the 11.x format. Easiest way to know would be to also do an export from 11.x and compare the files. Some times Cisco changes the format of the CSV files around, I guess it's to keep us on toe.
05-18-2020 07:05 AM
Added info, look at this post for the same thing. https://community.cisco.com/t5/unified-communications/how-to-bulk-import-translation-patterns-to-cucm/m-p/3224561
