Impossible to enable Extension Mobility
massigallina
Good morning everybody,
I'm trying to configure Extension Mobility on a CUCM version 9, but I am experiencing a very strange problem. I have tried to find a solution over the Internet, but with no success. So maybe some expert can help me.
There are two strange things happening:
1) When I go to the End User configuration, I check the "Enable Mobility" flag, but there is no "Primary User Device" box. I mean, the box is absent, so there is no device to choose from. Anyway, I decided to move on. I correctly created a new Remote Destination Profile, but
2) when I add a new remote destination, I get this message: typedberrors REMOTEDESTINATION_MOBILITY_NOT_ENABLED
Can anybody help me with this?
Thank you very much!
Massimo
Aaron Harrison
Extension Mobility, and the Mobility feature you are trying to configure are completely separate features.
Which one are you actually trying to configure?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Dragan Ilic
Level 4
Level 4
In addition to Aaron answer - please follow step-by-step guide from:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a0080153e60.html
And it should work...
BR,
Dragan
HTH,
Dragan
