Improving the conference
Jean Lofrano
Hi Voice team,
I can to do conference just between 4 internal users..
How can I to improve my solution? I want to do conference with 8 internal users....
I need more PVDM?
I´m using a 2821 to manage the codecs in a conference.
sccp local GigabitEthernet0/0.20
sccp ccm 172.20.1.106 identifier 1 priority 1 version 4.1
sccp
sccp ccm group 1
description *** config para conferencia ***
bind interface GigabitEthernet0/0.20
associate ccm 1 priority 1
associate profile 7 register XCODER
dspfarm profile 7 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 2
associate application SCCP
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821         , VID: V01 , SN: FTX0919A01F
NAME: "WAN Interface Card - Serial 2T", DESCR: "WAN Interface Card - Serial 2T"
PID: WIC-2T=           , VID: 1.0, SN: 28425856
NAME: "One port E1 voice interface daughtercard", DESCR: "One port E1 voice interface daughtercard"
PID: VWIC-1MFT-E1=     , VID: 1.0, SN: 30225314
NAME: "PVDMII DSP SIMM with four DSPs", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: FOC130410QS
PID: PVDM2-64          , VID: V01 , SN: FOC12510WCM
NAME: "Virtual Private Network (VPN) Module", DESCR: "Encryption AIM Element"
PID: AIM-VPN/EPII-PLUS , VID:   NA, SN: FOC09111HEJ
NAME: "NM-SE", DESCR: "NM-SE"
PID: NM-CUE            , VID: V03, SN: FOC120137RY
NAME: "40GB IDE Disc Daughter Card", DESCR: "40GB IDE Disc Daughter Card"
PID:                   , VID: 1.0, SN: FOC115265SW
Change the "MaxAdHocConference" and "MaxMeetMe Conference" CUCM service parameters to 8, by default they are set to 4.
HTH,
Chris
6 Replies 6
Aaron Harrison
CME? CUCM?
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
CUCM..software conference...
HTH,
Chris
Thanks Chris.
I have another doubt:
- My environment is:
CUCM (software bridge) and transcode on the local VG < > WAN < > CME conference
How Can I to improve the number of the conference participants between the sites?
thanks
What do you want to improve?  The parameter you changed apply to all conferences initiated from CUCM side, if you want to allow more than 3 participants for conferences initiated on CME side you need to use hardware bridge on CME as the software CME bridge is limited to only 3 participants.
HTH,
Chris
Rob Huffman
Hi Jean,
Just to add a note to the great tips from Chris, check out this excellent doc from Tony @ Cisco
https://supportforums.cisco.com/docs/DOC-9464
Cheers!
Rob
