07-23-2014 08:47 PM - edited 03-16-2019 11:30 PM
We are upgrading from CUCM 7.1. The new cluster is v9.1 and it was initially configured by restoring an OLD backup of 7.1..
During the upcoming cutover, we want to maintain the most current call forwarding settings for all users/phones.
Where is the list of forwarded phones and related information for each stored in CUCM database?
Is this information stored in one of the tables that can be exported using BAT? If so we could export, normalize to 9.1 and import it.
Getting a new full backup from the live CUCM 7.1 and restoring on the new CUCM 9.1 is not a viable option due to other reasons.
Thanks in advance for any help.
07-23-2014 11:07 PM
This information saved in table "CallForwardDynamic" but not sure how to get it using BAT. You can try with sql query.
Suresh
07-29-2014 06:03 AM
As an example you could use something like
run sql select np.dnorpattern, np.alertingname, cfd.cfadestination from callforwarddynamic cfd, numplan np where cfd.fknumplan=np.pkid and cfd.cfadestination matches '[0-9]*'
Maybe you have to use something like
run sql ccm select np.dnorpattern, np.alertingname, cfd.cfadestination from callforwarddynamic cfd, numplan np where cfd.fknumplan=np.pkid and cfd.cfadestination matches '[0-9]*'
on CUCM 7.1.
to get the numeric CFA destinations in your cluster.
Andre
