01-19-2017 05:56 PM - edited 03-17-2019 09:15 AM
I need to delete all inactive users from CUCM. I have LDAP integration with my CUCM (System version: 11.5.1.10000-6) "Inactive LDAP Synchronized User"
Error occurred. One or more record did not get deleted. Users added from corporate directory sync cannot be modified manually. |
So I found that link and applied but no luck
I also restarted CUCM cluster. Any idea?
01-19-2017 09:15 PM
Hi Ekin,
It is most likely due to end user association on Phone, line, remote destination etc. You may refer the following to determine the same
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117726-technote-cucm-00.html#anc9
Manish
01-20-2017 07:55 AM
Not sure I'm following what you want, but once users are in inactive state, the one who is in charge of deleting them, is the garbage collector.
07-31-2017 08:44 AM
I have the same issue.
02-12-2018 10:30 AM
Do you still have this issue ?
Does the user have a Jabber account ?
02-24-2021 06:42 AM
The link is broken
02-25-2021 05:54 AM
As Jamie mentioned, Garbage Collection is responsible for removing inactive LDAP users from the CUCM. I linked to the section in the SRND doc for CUCM 11.x below for reference. As far as I know there is no manual way to force this process, but someone feel free to correct me if I'm wrong.
