07-16-2014 01:21 AM - last edited on 03-25-2019 08:30 PM by ciscomoderator
Hi Guys,
When checking the voice router, I found out that all the active calls are matching dial-peer 0, including inbound and outbound call legs
CallID CID ccVdb Port Slot/DSP:Ch Called # Codec MLPP Dial-peers
0x1281AA 25B1 0x2446AA68 0/0/1:15.29 0/1:3 * g711ulaw 0/0
0x12821F 25E4 0x2446AA68 0/0/1:15.25 0/1:6 * g711ulaw 0/0
0x128230 25EB 0x2446AA68 0/0/1:15.23 0/1:9 * g711ulaw 0/0
0x128275 2605 0x2446AA68 0/0/1:15.30 0/1:2 * g728 0/0
0x12828F 2612 0x2446AA68 0/0/1:15.26 0/1:7 * g729r8 0/0
0x1282F8 2635 0x2446AA68 0/0/1:15.24 0/1:8 * g728 0/0
0x1282FC 2637 0x2446AA68 0/0/1:15.22 0/1:10 * g711ulaw 0/0
The gateway is MGCP. Does it look normal?
Jim
07-16-2014 02:07 AM
From which output you get to know that its matching dial-peer 0 ? Because the output of show voice call status in MGCP does not show dial-peer and its working as designed.
As you are using E1 PRI , the call will be backhauled to CUCM. Its only show dial-peer number when call goes through analog port.
Manish
07-16-2014 02:17 AM
MGCP purpose is just in that - doing all config from CM and controling your gateway totally from there.
So this is just normal operation in your environment...
BR,
Dragan
