Inbound and Outbound errors SIP Trunk CUBE -CUCM
tresdeasada
Hi everyone!
I have some issues with SIP Trunk calls.
My scheme is the following:
SIP PSTN --> CUBE --> SIP Trunk to CUCM
We just change our headquarters location and we brought or equipment with us, previously the SIP Trunk worked and here the problems started. Can't make inbound or outbound calls.
I attached the CUBE  configuration and the debugs with the corresponding errors.
Hope you can read it and help me.
Thanks!
bichacko
HI,
Did you happen to make any modifications during re-location?
Unfortunately the debugs are not complete and don't give a good insight on the issue.
However, I would suggest you to check your dial-peers, as I only see 2 pointing to SIP server:
dial-peer voice 2000 voip
translation-profile outgoing out
destination-pattern .T
session protocol sipv2
session target sip-server
voice-class codec 10
dtmf-relay rtp-nte
no vad
dial-peer voice 1 voip
translation-profile incoming Inbound
incoming called-number .%
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
no vad
sip-server dns:siptrunk.net2phone.com
*Feb 8 18:02:29.624: //78569/4187EA000000/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 1
Disconnect Cause (SIP) : 404
Bijo
Chris Deren
Post full debugs as ones you posted are incomplete.
Did any IP addresses change during the move i.e. of CUCM and/or CUBE?
Is SIP Options Ping enabled and SIP trunk shows Up status in CUCM?
