01-31-2008 04:20 AM - edited 03-15-2019 08:32 AM
Hi!
I have defined Meet-Me number. How can I restrict access to this number (calls from PSTN), in the way that only specific external telephone number can access this pattern?
Is this possible?
thx
01-31-2008 04:24 AM
Do you have CME or CM and which version., If the latter are you using H.323 or MGCP to the GW ?
01-31-2008 04:34 AM
sorry, here is the info
CM 4.1(3) with MGCP
01-31-2008 06:24 AM
If you have Unity or IPCC , you can do a supervised transfer, where the User should provide a PIN and tell his Name before he get connected to the Meet-Me conference.
There is no other solution for this problem.
