Walkthrough Wednesdays
547
gary.hicks
Beginner
Inbound call on h323 gateway problem with calling party info
I am setting up a router at a remote site to do just 911 calling with one FXO port connected to a pots line..  I have set it up to accept inbound calls as well such as for PSAP callback
The odd thing is that when I call in the caller on my phone shows 9911 as the caller.  debug voice ccapi all shows copying 9911 to calling party.
Attached are the dial-peers on the router, the voice port configuration and the output of the debug voice CCAPI.  any ideas why  I am getting 9911 as the caller ID on the internal phone would be appreciated....
Debug voice CCAPI all:
*Nov 17 15:27:42: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   Call Entry Is Not Found
*Nov 17 15:27:50: //-1/0901AC258114/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3427
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=0   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Nov 17 15:27:50: //-1/0901AC258114/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x6849C4BC, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3427(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=9911, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
   (calling is null, answer_addr=, dest_pattern=9911,
   e164_ans_addr=0, e164_dest_pattern=1)
   valid dest pattern, copying 9911 to calling number
   Interface Type=2, Protocol=0
*Nov 17 15:27:50: //-1/0901AC258114/CCAPI/ccCheckClipClir:
   In: Calling Number=9911(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Calling Party Number Is User Provided
   Out: Calling Number=9911(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
*Nov 17 15:27:50: //109/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=0, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=1
*Nov 17 15:27:50: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Nov 17 15:27:50: :cc_get_feature_vsa malloc success
*Nov 17 15:27:50:  cc_get_feature_vsa count is 1
*Nov 17 15:27:50: :FEATURE_VSA attributes are: feature_name:0,feature_time:1785330000,feature_id:109
*Nov 17 15:27:50: //-1/xxxxxxxxxxxx/CCAPI/cc_init_call_entry:
*Nov 17 15:27:50:  call_init_entry calle is 6A6797A8,callid is 109
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/cc_insert_guid_pod_entry:
   Incoming=TRUE, Call Id=109
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=9911(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3427(TON=Unknown, NPI=Unknown))
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/cc_process_call_setup_ind:
   Event=0x68453A68
*Nov 17 15:27:50: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_registration_lookup:
   Matching Parameters; Called Number=3427, Call Transfer Consult Id=
*Nov 17 15:27:50: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Searching Node;
*Nov 17 15:27:50: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_compare:
*Nov 17 15:27:50: Comparing SSOpCode; 0x50 and 0x0
*Nov 17 15:27:50: Comparing SSOpCode; 0x12 and 0x0
   Try with the demoted called number 3427
   No Matching Node
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccCallSetContext:
   Context=0x6AB4E7C4
   >>>>CCAPI handed cid 109 with tag 9911 to app "_ManagedAppProcess_Default"
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=2, Params=0x6AB4FB1C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccCheckClipClir:
   Destination Pattern=3427, Called Number=3427, Digit Strip=FALSE
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=TRUE,
   Guid=0901AC25-6DCF-11E4-8114-C53D69863640, Outgoing Dial-peer=2
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=9911
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=3427
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x679D317C, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=9911,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=3427(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Nov 17 15:27:50: //110/xxxxxxxxxxxx/CCAPI/cc_insert_call_entry:
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=FALSE)
*Nov 17 15:27:50:  cc_get_feature_vsa count is 2
*Nov 17 15:27:50: :FEATURE_VSA attributes are: feature_name:0,feature_time:1785329776,feature_id:110
*Nov 17 15:27:50:  call_init_entry calle is 6A678BD0,callid is 110
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/cc_peer_bind:
   Bind=TRUE, Binder Call Id=109, Bindee Call Id=110
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_insert_guid_pod_entry:
   Incoming=FALSE, Call Id=110
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccCallSetupRequest:exit@2521
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/ccCallSetContext:
   Context=0x6AB4FACC
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccSaveDialpeerTag:
*Nov 17 15:27:50: //-1/xxxxxxxxxxxx/CCAPI/cc_api_supported_data:
   data_mode=0x10082
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_incr_if_call_volume:
   Remote IP Address=10.8.5.11, Hwidb=FastEthernet0/1
   Total Call Count=1, Voip Call Count=1, MMoip Call Count=0
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_call_proceeding:
   Interface=0x679D317C, Progress Indication=NULL(0)
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_call_proceeding:exit@7008
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_call_alert:
   Interface=0x679D317C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x679D317C, Call Id=110
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_call_notify:exit@7949
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
*Nov 17 15:27:50: //110/0901AC258114/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
*Nov 17 15:27:50: //109/0901AC258114/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=109
*Nov 17 15:27:53: //110/0901AC258114/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_call_connected:
   Interface=0x679D317C, Data Bitmask=0x0, Progress Indication=NULL(0),
   Connection Handle=0
*Nov 17 15:27:54: //-1/xxxxxxxxxxxx/CCAPI/cc_set_conf_start_tstamp:
   CALL_ERROR_INFORMATIONAL;
*Nov 17 15:27:54:  cc_set_conf_start_tstamp: no confID set - confID:0
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_call_connected:exit@5772
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_set_called_ccm_detected:
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_call_notify:
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_call_notify:exit@7949
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=109
*Nov 17 15:27:54: //109/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x67983B94, callID1=0x6D, callID2=0x6E, tag=0x0)
   (confID=0x67983B94, callID1=0x6D, gcid=901AC25-6DCF11E4-8114C53D-69863640, tag=0x0)
*Nov 17 15:27:54: //110/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x67983B94, callID2=0x6E, gcid=901AC25-6DCF11E4-8114C53D-69863640, tag=0x0)
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/ccConferenceCreate:
   Conference Id=0x67983B94, Call Id1=109, Call Id2=110, Tag=0x0
*Nov 17 15:27:54: //109/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x12, Source Interface=0x6849C4BC, Source Call Id=109,
   Destination Call Id=110, Disposition=0x0, Tag=0xFFFFFFFF
*Nov 17 15:27:54: //110/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
*Nov 17 15:27:54: cc_api_get_xcode_stream : 4534
*Nov 17 15:27:54: //110/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x12, Source Interface=0x679D317C, Source Call Id=110,
   Destination Call Id=109, Disposition=0x0, Tag=0x0
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x12, Destination Call Id=110)
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x12, Destination Call Id=109)
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_api_caps_ind:
   Destination Interface=0x679D317C, Destination Call Id=110, Source Call Id=109,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x12, Call Id1=109, Call Id2=110
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_caps_ind:
   Destination Interface=0x6849C4BC, Destination Call Id=109, Source Call Id=110,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1869)
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_api_caps_ack:
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_get_ccm_detected:
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/ccCallNotify:
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_api_voice_mode_event:
   Call Id=109
   Call Entry(Context=0x6AB4E7C4)
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x0
   Call Entry(Connected=TRUE, Responsed=TRUE)
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x679D317C, Call Id=110
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/ccConferenceDestroy:
   Conference Id=0x12, Tag=0x0
*Nov 17 15:27:54: //-1/xxxxxxxxxxxx/CCAPI/ccConferenceDestroy:
   CALL_ERROR_INFORMATIONAL; mute call detection failed with confID=0x12
*Nov 17 15:27:54: //109/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=110, Disposition=0x0, Tag=0x0
*Nov 17 15:27:54: //110/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
*Nov 17 15:27:54: //-1/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
   CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Start Calling Accounting;
   Call Entry(Incoming=TRUE)
   Cause Value=16, Call Entry(Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
   Call Entry(Incoming=FALSE)
   Cause Value=16, Call Entry(Disconnect Cause=16)
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_get_transfer_info:
*Nov 17 15:27:54: //-1/xxxxxxxxxxxx/CCAPI/cc_api_icpif:
   ExpectFactor=0xA
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_decr_if_call_volume:
   Total Call Count=0, Voip Call Count=0, MMoip Call Count=0
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x679D317C, Tag=0x0, Call Id=110,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_delete_guid_pod_entry:
   Incoming=FALSE
*Nov 17 15:27:54: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Nov 17 15:27:54: :cc_free_feature_vsa freeing 6A69F868
*Nov 17 15:27:54:  vsacount in free is 1
*Nov 17 15:27:54: //110/0901AC258114/CCAPI/cc_delete_call_entry:
   Deleting profileTable[0x6A5213E0]
*Nov 17 15:27:54: //0/xxxxxxxxxxxx/CCAPI/cc_get_call_entry:
*Nov 17 15:27:54: //0/xxxxxxxxxxxx/CCAPI/cc_api_call_preempt_done:
   CALL_ERROR_INFORMATIONAL; Call Entry Is Not Found
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x6849C4BC, Tag=0x0, Call Id=109,
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_delete_guid_pod_entry:
   Incoming=TRUE
*Nov 17 15:27:54: //109/0901AC258114/CCAPI/cc_delete_call_entry:
   ccFreeRawMsgInfo=0x68459E58
*Nov 17 15:27:54: :cc_free_feature_vsa freeing 6A69F948
*Nov 17 15:27:54:  vsacount in free is 0
   Total Call Count=1, Call Entry(Call Count On=FALSE, Incoming Call=TRUE)
   Total Call Count=0
   Deleting profileTable[0x6A51FC98]
DIAL Peers:
dial-peer voice 2 voip
 destination-pattern 3427
 voice-class codec 1
 voice-class h323 1
 session target ipv4:10.8.5.11
 incoming called-number .
 dtmf-relay h245-alphanumeric
 ip qos dscp cs5 media
 no vad
dial-peer voice 9911 pots
 destination-pattern 9911
 port 0/0/0
 forward-digits 3
voice-port 0/0/0
 connection plar 3427
caller-id enable
Gary
1 REPLY 1
Zekeria Sammantar
Participant
Use the below debug to clarify which number are you calling from and the number called.
Debug voip dialpeer inout
Content for Community-Ad
Spotlight Awards 2021
