01-28-2014 05:46 AM - edited 03-16-2019 09:28 PM
I have a quick question about the parameter significant digit for inbound call, I know how it work but I had a serious dellema.
In fact for one of my client I have internal dial plan with for digit but significant digit is configured to passe all digit to call manager and it's still working.
Even if in debug ISDN Q931 I see called number only four Digit.
Is there any other parameter where this option could be configured (CSS transformation are not configured)?
Thank you for your answer
Solved! Go to Solution.
01-28-2014 06:10 AM
If you see 4 digits in the Q931 debug the provider is only delivering 4 digits, so that is why the call works if you have significant digits set to 4 as well as if you have significant digits set to all.
01-28-2014 06:10 AM
"In fact for one of my client I have internal dial plan with for digit but significant digit is configured to passe all digit to call manager and it's still working. Even if in debug ISDN Q931 I see called number only four Digit."
>> you receive 4 digit called number and you passed all the 4 digits to CUCM. So it is working as your internal dial plan is also 4 digits.
Please rate all the useful posts
01-28-2014 05:56 AM
Check out Translation pattern in CUCM and Translation rule in Voice gateway.
Rate all the helpful post.
Manish
01-28-2014 06:04 AM
Hi Manish,
I have MGCP Gateway, and i don't have any translation pattern:(
01-28-2014 06:10 AM
01-28-2014 06:10 AM
01-28-2014 06:28 AM
Hello
I confirmed from the operator that he is sending only 4 digits.
Thank you for your support
01-28-2014 06:46 AM
debug isdn q931 command will tell you how many digits we are sending/receiving as calling/called number to/from the operator.
