Inbound call to VoiceGateway Router is not working during SRST
cnorton
                   Hi guys, I hope you can help me on our problem with our IPT. We cant do inbound call to our voice gateway router during SRST but outboud calls is working. On debug isdn q931 shows that number is unallocated. But debug translation shows the number is being translated correctly. Debug dialpeer shows that no outgoing dial-peer is matched, show dialplan number also shows no match. Attached here is the running config and the debug result. Hope someone can help us.
thanks in advance
12 Replies 12
Ayodeji Okanlawon
From the show ephone registered..The phones do not seem to have a line on them...  We cant see any dn assigned to the phone
ephone-1[0] Mac:7487.AAC7.240A TCP socket:[1] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 9/9 max_streams=1
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:8
IP:10.120.86.2 47473 SCCP Gateway (AN)  keepalive 86922 max_line 1 available_line 1 (even though we see available line, we dont see a DN)
port 2/0/10
Preferred Codec: g711ulaw
ephone-2[1] Mac:7487.A81B.B409 TCP socket:[29] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 9/9 max_streams=1
IP:10.120.86.3 59743 SCCP Gateway (AN)  keepalive 86904 max_line 0 available_line 0
port 2/0/9
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Hi aokanlawon,
those are for the analog phones, however the ip phone do have dn assigned to them. See below
phone-32[31] Mac:0019.AA44.8BA0 TCP socket:[69] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=5
mediaActive:0 whisper_mediaActive:0 startMedia:0 offhook:0 ringing:0 reset:0 reset_sent:0 paging 0 debug:0 caps:11
IP:10.171.69.98 36630 7970  keepalive 195 max_line 8 available_line 1
button 1: dn 73 number 877028551  CM Fallback CH1   IDLE         CH2   IDLE
speed dial 1:8503 Client Services
ephone-33[32] Mac:0019.56FD.654C TCP socket:[56] activeLine:0 whisperLine:0 REGISTERED in SCCP ver 17/12 max_streams=5
IP:10.171.69.27 20951 7970  keepalive 196 max_line 8 available_line 1
button 1: dn 56 number 877028896  CM Fallback CH1   IDLE         CH2   IDLE
speed dial 1:8503 Regus at your Service
My concern is how come its not matching the dialpeer? Im pretty sure that the configuration is correct
Here are the sample voice port summary
20001  pots  up   up             877028562$         2                           50/0/1
20002  pots  up   up             877028822$         2                           50/0/2
20003  pots  up   up             877024000$         2                           50/0/3
20004  pots  up   up             877028835$         2                           50/0/4
20005  pots  up   up             877028620$         2                           50/0/5
20006  pots  up   up             877028896$         2                           50/0/6
20007  pots  up   up             877028536$         2                           50/0/7
20008  pots  up   up             877028521$         2                           50/0/8
20009  pots  up   up             877028561$         2                           50/0/9
20010  pots  up   up             877028539$         2                           50/0/10
20011  pots  up   up             877028808$         2                           50/0/11
20012  pots  up   up             877028847$         2                           50/0/12
20013  pots  up   up             877028596$         2                           50/0/13
20014  pots  up   up             877028682$         2                           50/0/14
20015  pots  up   up             877028685$         2                           50/0/15
20016  pots  up   up             877028608$         2                           50/0/16
20017  pots  up   up             877028512$         2                           50/0/17
20018  pots  up   up             877028513$         2                           50/0/18
20019  pots  up   up             877028551$         2                           50/0/19
20020  pots  up   up             877021102$         2                           50/0/20
20021  pots  up   up             877028831$         2                           50/0/21
20022  pots  up   up             877028619$         2                           50/0/22
20023  pots  up   up             877021101$         2                           50/0/23
20024  pots  up   up             877028538$         2                           50/0/24
20025  pots  up   up             877028897$         2                           50/0/25
20026  pots  up   up             877028597$         2                           50/0/26
20027  pots  up   up             877028577$         2                           50/0/27
20028  pots  up   up             877024006$         2                           50/0/28
20029  pots  up   up             877028697$         2                           50/0/29
20030  pots  up   up             877028625$         2                           50/0/30
20031  pots  up   up             877028810$         2                           50/0/31
20032  pots  up   up             877028635$         2                           50/0/32
20033  pots  up   up             877028677$         2                           50/0/33
20034  pots  up   up             877028849$         2                           50/0/34
20035  pots  up   up             877028609$         2                           50/0/35
20036  pots  up   up             877028552$         2                           50/0/36
20037  pots  up   up             877028618$         2                           50/0/37
dial-peer voice 900 pots
description PRI to Telco
translation-profile incoming srst-10-to-9-digit
translation-profile outgoing srst-clid
destination-pattern 9T
service mgcpapp
incoming called-number .
fax rate disable
direct-inward-dial
port 0/0/0:23
dial-peer voice 901 pots
preference 1
service mgcpapp
fax rate disable
direct-inward-dial
port 0/0/1:23
Here are the dial-peer config
preference 2
service mgcpapp
fax rate disable
direct-inward-dial
port 0/0/0:23
preference 1
service mgcpapp
fax rate disable
direct-inward-dial
port 0/0/1:23
If someone out ther who can figure this out, i need your help. Thanks
Please remove the service mgcpapp from the dial-peer 900 and 901.
Do another test call..and send debug isdn q931
HI aokanlawon,
I have removed the mgcapp service but stil getting the same result
7702-18-1-RTR01#show run | s dial-peer voice 900 pots
preference 1
fax rate disable
direct-inward-dial
port 0/0/0:23
forward-digits 9
7702-18-1-RTR01#show run | s dial-peer voice 901 pots
preference 2
fax rate disable
direct-inward-dial
port 0/0/1:23
forward-digits 9
7702-18-1-RTR01#
005507: Sep  9 08:29:39: ISDN Se0/0/1:23 Q931: RX <- SETUP pd = 8  callref = 0x0B66
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98381
                Exclusive, Channel 1
        Progress Ind i = 0x8281 - Call not end-to-end ISDN, may have in-band info
        Calling Party Number i = 0x1183, '85231278477'
                Plan:ISDN, Type:International
        Called Party Number i = 0xA1, '2049268500'
                Plan:ISDN, Type:National
005508: Sep  9 08:29:39: ISDN Se0/0/1:23 Q931: Received SETUP  callref = 0x8B66 callID = 0x0067 switch = primary-ni interface = User
7702-18-1-RTR01#
005509: Sep  9 08:29:39: ISDN Se0/0/1:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x8B66
005510: Sep  9 08:29:39: ISDN Se0/0/1:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x8B66
        Cause i = 0x8081 - Unallocated/unassigned number
005511: Sep  9 08:29:39: ISDN Se0/0/1:23 Q931: RX <- RELEASE pd = 8  callref = 0x0B66
005512: Sep  9 08:29:39: ISDN Se0/0/1:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x8B66
OK, the isdn leg will not show us if the voice xlation is working..So lets try the "debug voip ccapi inout"
Please do a test call and send me the output of debug voip ccapi inout
I think the issue is being caused by the number expansion statements in your config.
num-exp 1... 817031...
num-exp 2... 817032...
num-exp 3... 817033...
num-exp 4... 817034...
num-exp 5... 817035...
num-exp 6... 817036...
num-exp 7... 817037...
The call you have shown in yor Q931 debug shows the called number as:-
The number expansion "num-exp 2... 817032..." will be changing this to:-
817032049
Try negating the number expansion and retest
no num-exp 2... 817032...
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hi acampbell,
Sorry its my fault, i attached a wrong config file. That config is for another router on our site. I'll attach the correct one so kindly review it again.
Thanks so much
Hi Aokanlawon,
Here is the CCAPI debug result. Also i noticed that the router is failing to download the xml file from ccm. Can that also cause this issue?
7702-18-1-RTR01#show ccm
MGCP Domain Name: 7702-18-1-RTR01.connectregus.com
Priority        Status                   Host
Primary         Registered               10.224.16.10
First Backup    Backup Ready             10.224.16.9
Second Backup   None
Current active Call Manager:    10.224.16.10
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            22:57:37 GMT Sep 10 2012 (elapsed time: 00:00:08)
Last MGCP traffic time:         22:57:37 GMT Sep 10 2012 (elapsed time: 00:00:08)
Last failover time:             17:33:50 GMT Sep 9 2012 from (10.224.16.10)
Last switchback time:           17:34:35 GMT Sep 9 2012 from (10.224.16.9)
Switchback mode:                Graceful
MGCP Fallback mode:             Enabled/OFF
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Backhaul Link info:
    Link Protocol:      TCP
    Remote Port Number: 2428
    Remote IP Address:  10.224.16.10
    Current Link State: OPEN
    Statistics:
        Packets recvd:   3216
        Recv failures:   0
        Packets xmitted: 4244
        Xmit failures:   0
    PRI Ports being backhauled:
        Slot 0, VIC 0, port 1
        Slot 0, VIC 0, port 0
Configuration Auto-Download Information
No configurations downloaded
Current state: Downloading XML file
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 0
          Download Failed              : 0
          TFTP Download Failed         : 671 <<<<<<<<<<<<<<<<<
        Configuration Attempted        : 0
          Configuration Successful     : 0
Looking at the traces the called number is not xlated...
002778: Sep 10 23:33:43:  vsacount in free is 0
002779: Sep 10 23:33:45: //-1/CC17E1988347/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=85231278477
   cisco-anitype=1
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=2049268500
   cisco-desttype=2
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
002780: Sep 10 23:33:45: //-1/CC17E1988347/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x696441A8, Call Info(
   Calling Number=85231278477,(Calling Name=)(TON=International, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=2049268500(TON=National, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=900, Progress Indication=NULL(0), Calling IE Present=TRUE,
Looking at your config... ( i dont see a clation for the dialled number 2049268500 is there something mssing in the config
voice translation-rule 1
rule 1 /^5142287400/ /817034000/
rule 2 /^5142287499/ /915135871660/
rule 3 /^5142287497/ /817034400/
rule 4 /^51422874/ /8170374/
rule 5 /^51422875/ /8170375/
voice translation-rule 2
rule 1 /817034000/ /5142287400/
rule 2 /^817037/ /5142287/
voice translation-profile srst-10-to-9-digit
translate called 1
voice translation-profile srst-clid
translate calling 2
Hi aokanlawon,
The attached config file was incorrect. I attached the correct one on my previuos entry. Here is the configuration of the translation rule -
rule 1 /^2049268500/ /877024000/
rule 2 /^2049268599/ /915135871660/
rule 3 /^20492685/ /8770285/
rule 4 /^20492686/ /8770286/
rule 5 /^20492688/ /8770288/
rule 1 /877024000/ /2049268500/
rule 2 /^8770285/ /20492685/
rule 3 /^8770286/ /20492686/
rule 4 /^8770288/ /20492688/
Im pretty sure its working since on my debug dial-peer, the number is translated to the correct 9 digit number
002660: Sep 10 23:27:48: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=85231278477, Called Number=2049268500, Voice-Interface=0x696441A8, <<<<<<<<<<<<<<<<<<< called number
   Timeout=TRUE, Peer Encap Type=ENCAP_VOICE, Peer Search Type=PEER_TYPE_VOICE,
   Peer Info Type=DIALPEER_INFO_SPEECH
002661: Sep 10 23:27:48: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=900
002662: Sep 10 23:27:48: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Calling Number=85231278477, Called Number=2049268500, Voice-Interface=0x0,
   Peer Info Type=DIALPEER_INFO_FAX
002663: Sep 10 23:27:48: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
   Result=NO_MATCH(-1) After All Match Rules Attempt
002664: Sep 10 23:27:48 GMT: %CALL_CONTROL-6-APP_NOT_FOUND: Application mgcpapp in dial-peer 900 not found.  Handing callid 1659 to the alternate app default.
002665: Sep 10 23:27:48: //-1/F792BE758343/DPM/dpMatchPeersCore:
   Calling Number=, Called Number=877024000, Peer
7702-18-1-RTR01# Info Type=DIALPEER_INFO_SPEECH
002666: Sep 10 23:27:48: //-1/F792BE758343/DPM/dpMatchPeersCore:
   Match Rule=DP_MATCH_DEST; Called Number=877024000 <<<<<<<<<<<<<<<<<<<< Xlated called number
002667: Sep 10 23:27:48: //-1/F792BE758343/DPM/dpMatchPeersCore:
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
002668: Sep 10 23:27:48: //-1/F792BE758343/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
7702-18-1-RTR01#show ephone registered | i 877024000
button 1: dn 38 number 877024000  CM Fallback CH1   IDLE         CH2   IDLE         shared
TAG    TYPE  MIN  OPER PREFIX    DEST-PATTERN      FER THRU SESS-TARGET    STAT PORT
20422  pots  up   up             877028521$         0                           50/0/36
20423  pots  up   up             877028852$         0                           50/0/37
20424  pots  up   up             877024000$         0                           50/0/38 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<,
20425  pots  up   up             877028609$         0                           50/0/39
20426  pots  up   up             877028638$         0                           50/0/40
20427  pots  up   up             877028853$         0                           50/0/41
ok I agree that the xlation looks to be working..but i dont see the xlated number on the ccapi debu..Can you try two things
1. rename the xlation profile to something smaller eg srst_in
translate called 1
2. can you also try remove the number expansion just to test..
lets know the results
This issue was resolved after we upgraded the IOS. Thank guys!
