ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
Beginner
Inbound called party number translation -- variable lengths!
Hi everyone,
We are implementing a new MGCP gateway in a remote office in Europe, and thus, we have variable number lengths that are standard in this country (Germany). What we need is a way to translate the called number into a different format so it matches internal DNs that we have defined within CallManager.
For example, we need to translate any of the called numbers, such as 54390, 543920, or 5439240 to internal extensions. Our private DN numbering plan is set up so that 22 is the prefix, followed by 3 digits.
So ideally, I need a way to translate as follows:
54390 --> 22000
543920 --> 22020
5439240 --> 22240
One could also write this as follows (if we wish to discard the digits PreDot):
5439.X --> 2200X
5439.XX --> 220XX
5439.XXX --> 22XXX
Can someone please explain to me how to apply this translation pattern INBOUND on our MGCP gateway, so that calls received on the gateway (that match any of these patterns) are routed to the correct DN internally?
Thank you!
4 REPLIES 4
Highlighted
Hall of Fame Master
Are you saying you have variable length DIDs provided from telco at this location?  I find this odd.
Either way if this is indeed the case and if they overlap you will need to create as specific TPs as possible and ensure that the "urgent priority" is not checked.
HTH,
Chris
Highlighted
Hall of Fame Master
Re: Inbound called party number translation -- variable lengths!
No isn't odd. Variable lenght numbering plans are present in many countries of the world.
As a consequence, one can receive vaitalve lenght DID, like for example xxx-xxxx-0 and xxx-xxxx-010, or even many more trailing digits.
However, as long overlaps are accuratly avoided, there is no problem at all in having that working.
Highlighted
Hall of Fame Master
Thanks Paolo,  I know it is common to have variable length dial plans, but I did not think it was common to have DID ranges of multiple lenghts at the same location, at least I've never run into it with my "limited" international deployments, but I've only dealt with couple dozen countries.
HTH,
Chris
Highlighted
Beginner
Indeed, it is at least common in Germany, where there are many, many different dialing lengths for DIDs. I was able to solve this, by the way. Here is my solution:
We need to create three translation patterns (TPs), one for each of the dialed strings above (5439X, 5439XX, and 5439XXX). The translation patterns should be set to translate the called party to 2200X, 220XX, and 22XXX, respectively. All three of these TPs should be placed in a new, separate, Partition (we will call it INBOUND-P, for simplicity's sake). On each of these TPs, we also need to assign a CSS that has access to the internal extensions (ALL_PHONES-P or something). Then, we need to create a new CSS that contains just the INBOUND-P partition we created earlier. We need to assign this on the MGCP gateway under the inbound calls. If we set the significant digits to "All", and choose not to assign any prefix addition on the gateway, this will give us what we are after.
Hope this helps someone!
