Inbound calls going stright to MOH
Curtis Fuentes
            I am having an intermittent issue where inbound calls to a hunt group are going straight to MOH.  I am using call manager 8.6
7 Replies 7
moataz_mamdouh
Are you using a recording system ?
No the call comes in vian 800 to a hunt group and goes to unity for a call Handel. The call comes in you hear MOH then ring again and some time goes to you call cant be completed as dialed.
moataz_mamdouh
And what is the function of the call handler ? Call redirection ?
yes to redirect to Voice mail or SRN if its after hours.
moataz_mamdouh
Can you check the busy trigger under the voicemail ports
I dont see a busy trigger on the voice mail ports. By the way thank you for your help
moataz_mamdouh
Please provide a trace file of a failed call
