02-27-2014 12:43 PM - edited 03-16-2019 09:56 PM
I am having an intermittent issue where inbound calls to a hunt group are going straight to MOH. I am using call manager 8.6
02-27-2014 12:50 PM
Are you using a recording system ?
02-27-2014 12:52 PM
No the call comes in vian 800 to a hunt group and goes to unity for a call Handel. The call comes in you hear MOH then ring again and some time goes to you call cant be completed as dialed.
02-27-2014 12:54 PM
And what is the function of the call handler ? Call redirection ?
02-27-2014 12:59 PM
yes to redirect to Voice mail or SRN if its after hours.
02-27-2014 01:00 PM
Can you check the busy trigger under the voicemail ports
02-27-2014 01:11 PM
I dont see a busy trigger on the voice mail ports. By the way thank you for your help
02-27-2014 01:14 PM
Please provide a trace file of a failed call
