ā12-31-2018 08:23 PM - edited ā03-17-2019 01:53 PM
We are running Cisco Unified CM Administration System version: 11.5.1.12900-21. This is my first go at anything Cisco IP, so excuse my ignorance. We are able to call outbound, but when we call inbound, our SIP provider receives a 404 not found and then they forward the call. This happened out the blue with no config changes. I don't even how or what config to provide to get us on the right track.
Thanks, for any help in the right direction.
ā01-01-2019 01:14 AM
Sip error 404 is a generic error that implies that the call cannot be established. Ideally, you setup could be the following:
CUCM-(1)-CUBE-(2)-SIP Provider
So it is important to check the (1) SIP trunk configuration between your CUCM and your CUBE.
(CUCM Admin Page- Device- Trunk and select the corresponding trunk)
(2) Dial Peer Configuration between the CUBE and your Provider.
(sh run)
Please confirm that this is the schenario you are working with and we could get to more details.
G
G
ā01-01-2019 03:03 AM
Get the sip traced debug ccsip messages. And add to post. Also seeing you didnt didnt on your end call the provider and let them what the are not liking about your sip invite
ā01-01-2019 11:38 PM
ā08-07-2024 07:57 AM
Good afternoon, I am experiencing the same problem with my voice gateway. I can make calls to the PSTN, but incoming calls from the PSTN are not getting through. I will send the provider's logs below for your assistance.
Incoming SIP message received from 10.222.222.206:5060 to 41.221.248.10:5060 on service network 2:
Summary: 404 Not Found From: <sip:922293187@sbc1.mstelcom.com> To: <sip:226698956@sbc1.mstelcom.com>
SIP/2.0 404 Not Found
Via: SIP/2.0/UDP 41.221.248.10:5060;rport;branch=z9hG4bK+f4edc6a71583d489d8b4f4d58490407c1+sip+1+cd6afa63
From: <sip:922293187@sbc1.mstelcom.com>;tag=41.221.248.10+1+14dfc5b5+be256386;isup-oli=00
To: <sip:226698956@sbc1.mstelcom.com>;tag=10B378-B2D
Date: Wed, 07 Aug 2024 13:25:32 GMT
Call-ID: 0gQAAC8WAAACBAAALxYAAGwCWNl3BrHNPIQphW4JoOkKrQ9lkUpYb5u+FimiPlAA@41.221.248.10
CSeq: 672421192 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Reason: Q.850;cause=1
Content-Length: 0
Jump to Call Flow
ā08-07-2024 09:49 AM
I encourage you to start a new conversation with a full description of your issue, any versions of systems like CUCM that are involved, and then attach any logs or traces as attachments to your post (rather than embedding them if they are longer than a few lines). You will find a much better response than a reply to a years-old post.
Maren
