02-06-2013 08:52 PM - edited 03-16-2019 03:34 PM
HI,
I am using CUCM 8.5, SIP trunks to voice gateways using E1 / T1 lines. We have noticed that at some sites inbound calls that come from private numbers are shown on the phone as coming from "unknown" at some other sites on the same cluster and coming from the same telco the calls are seen as "private". I need to standize the display across all sites but I can see where this display is generated...
Any advice would be great appreiciated !!
02-07-2013 12:53 AM
please can you use this command
debug isdn q931 , and send the output.
Thank you
02-07-2013 06:41 PM
thanks for your offer to help :-)
Feb 6 04:01:33.258: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x0047
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA193040000
Preferred, Channel 4
Calling Party Number i = 0x00C3, N/A
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '2099103'
Feb 6 04:01:33.278: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x8047
Channel ID i = 0xA993040000
Exclusive, Channel 4
Feb 6 04:01:33.370: ISDN Se0/0/0:23 Q931: TX -> ALERTING pd = 8 callref = 0x8047
I have confirmed that other sites also get the "N/A" in the "Calling Party Number" field.
Cameron
02-08-2013 06:05 AM
Kindly find the below configuration , may be you missing the below
dial-peer voice 1 pots incoming called-number . direct-inward-dial ! dial-peer voice 2 voip description Incoming voip calls incoming called-number . voice-class codec 1 voice-class h323 1 dtmf-relay h245-alphanumeric no vad
Configure CM so that calling number plan/type is ISDN/national.
Otherwise, telco may not acknowledge as valid DID.
Other than that,
Thank you
02-08-2013 06:17 AM
the last thing , please mention the integration ( call flow ) , the existing devices in your network.The protocol ( MGCP or H323).
Thank you
