01-13-2022 04:28 AM - edited 01-13-2022 04:31 AM
Hi all,
I have recently taken up Collaboration switching over from networks. One of my current projects is troubleshooting an issue a client is having with their CME. They can receive incoming calls on their SIP registered numbers but outgoing calls are not working. Trying to place one shows an error of "Unknown number". I have tried to debug but for the love of me cannot figure out what's causing the issue. Bear in mind that their are two other SIP trunks from two other ITSPs that are working just fine. We had a session with engineers from the particular ITSP and they said they can see incoming calls register on their end but the outgoing calls do not register at all on their end meaning its most probably an issue on our end.
Any help would be greatly appreciated. Please let me know if you do require further information like the logs and the sort, which I will avail upon request. Thanks
01-13-2022 04:35 AM
could you share your config and the output of debug ccsip messages?
Are the SIP trunk on the CME correctly registered? (show sip-ua register status)
--- Please rate this post as "Helpful" or accept as a solution, if your question has been answered ---
01-13-2022 10:29 PM
To add to what @b.winter wrote please also enable debug voip ccapi inout at the same time as the other debug and collect the output in text files, one for debug and another for configuration that you attach to your response.
01-14-2022 12:25 AM - edited 01-14-2022 12:50 AM
Thank you @Roger Kallberg and @b.winter for the quick responses. Please find attached the config files and part of the debug. I am not so conversant on the debug procedure. I ran debug ccsip messages and debug voip ccapi inout but I was getting over 8000 lines of output. is there a more convenient way to display this output or you don't mind the length and I can just go ahead and share as is?
(Edited)NB: I have just attached the debug logs as well.
01-14-2022 12:35 AM
yes, you can share the whole debug.
Also don't forget the config and mask all the username / passwords in there.
01-14-2022 12:51 AM
Please refer to previous post. I have appended the debug logs to it as well
01-14-2022 01:01 AM
as your question has already been discussed in some other posts recently, please check them.
Examples here:
https://community.cisco.com/t5/unified-communications/sip-ua-outgoing-issue-cisco-cme/td-p/4525809
Advise here again:
Update to the newest recommended version (in your case 15.7 (3) M8)
Use tenant configuration for the connection to provider, as it is the current "standard" way to do this.
And also, it's a must, if you have SRST running on the same router. I don't know, if it is a must for CME too, but I could imagine that.
A lot of the configuration has already been discussed in those 2 example posts.
01-14-2022 02:50 AM
CME has the same requirements for this specifics as SRST. This is as they pretty much are based on the same underlying parts in IOS.
01-14-2022 02:49 AM
As @b.winter mentioned most of what can be seen as issues in the running configuration is addressed in the two referenced post. For the debug output it would be helpful to know the number of whom did the call, to what number the call was made to and at what time approximately? This is to narrow down what we're looking for in your massive output.
01-14-2022 03:26 AM - edited 01-15-2022 03:22 AM
The call is being placed from +25632xxxx530 to +25677930xxxxxx.
Calls from +2567xxxxx985. to +25632xxxxx530 work just fine but the reverse fails
01-14-2022 03:47 AM
I don't see the incorrect outbound call that you mentioned in the logs.
I only see an inbound call with those numbers.
01-14-2022 03:51 AM - edited 01-14-2022 03:53 AM
Could it be a rule translation error then? Because if it's not even registering in the logs then, something else is at play.
Could you kindly take a look at the translation rules and extrapolate if their needs to be a change..
PS: I did a change translation rule 2611 and when calling outside, it no longer says unknown number, but now says Busy.
01-14-2022 04:01 AM
Then take the logs with the following debugs:
debug voice translation
debug voice ccapi ind 1
debug voice ccapi ind 2
debug voice ccapi ind 74
01-14-2022 04:56 AM - edited 01-14-2022 05:01 AM
Translation rule 2611 is used in translation profile 2610 and that is used on dial peer 110 in the inbound direction. As such it should have nothing to do with your outbound calls. What dial peer are you expecting the call to use for the outbound direction?
01-15-2022 03:19 AM
Thank you @Roger Kallberg and @b.winter for all your input.
After much troubleshooting, it has been discovered that this is an ITSP issue. And as such, has been escalated to the responsible ITSP. A similar deployment exists at another client site with similar configs and is working fine. The ITSP will deal with the issue
