Inbound fax not working
amanchau
Inbound faxes not working, Below is the call flow :
Call Flow : PSTN --> ISDN PRI --> PTSN GW --> MGCP --> CUCM --> FXS GW --> FXS --> FAX Machine
i am attaching the debugs for the PSTN GW and the FXS GW.
Fax number : 5052229845
When we dial the fax number it keeps ringing and there is no fax tone as well. Any thoughts will be helpful.
Thanks & Regards
Jonathan Schulenberg
If the incoming call never answers then you need to look at the fax machine and confirm it’s set to auto answer.
