Incoming call can't match incoming dial-peer
bo liu
Level 4
Level 4
i config the dial-peer like this
dial-peer voice 1007 pots
 translation-profile incoming CallBack
 call-block translation-profile incoming call_block
 call-block disconnect-cause incoming call-reject
 incoming called-number 843791...
 fax rate disable
 direct-inward-dial
dial-peer voice 1008 pots
 incoming called-number 843792...
 fax rate disable
 direct-inward-dial
dial-peer voice 1006 pots
 translation-profile incoming E1-incoming
 service csyw
 incoming called-number 8437....
 fax rate disable
 direct-inward-dial
but when i dial a number 84379110,the call should match 1007 but it match 1006,why ????
.Oct 21 10:16:51.808: //-1/A039182898E2/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=13311173269
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=84379110
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
.Oct 21 10:16:51.808: //-1/A039182898E2/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x14FE6664, Call Info(
   Calling Number=13311173269,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=84379110(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=1006, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
.Oct 21 10:16:51.808: //-1/A039182898E2/CCAPI/ccCheckClipClir:
   In: Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
   Out: Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
.Oct 21 10:16:51.808: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
.Oct 21 10:16:51.808: :cc_get_feature_vsa malloc success
.Oct 21 10:16:51.808:  cc_get_feature_vsa count is 226
.Oct 21 10:16:51.808: :FEATURE_VSA attributes are: feature_name:0,feature_time:369343064,feature_id:936110
.Oct 21 10:16:51.808: //1460499/A039182898E2/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=13311173269(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=84379110(TON=Subscriber, NPI=ISDN))
.Oct 21 10:16:51.808: //1460499/A039182898E2/CCAPI/cc_process_call_setup_ind:
   Event=0x245DBE0
.Oct 21 10:16:51.808: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 84379110
.Oct 21 10:16:51.812: //1460499/A039182898E2/CCAPI/ccCallSetContext:
   Context=0x133506C4
.Oct 21 10:16:51.812: //1460499/A039182898E2/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 1460499 with tag 1006 to app "_ManagedAppProcess_CSYW"
.Oct 21 10:16:52.008: //1460496/9FBDCD5298E1/CCAPI/ccCallSetupAck:
Hi.
This because dialpeer is more specific for dialed number
On DP 1007 you have
incoming called-number 843791... ( 3 dots)
while on DP 1006 you have
incoming called-number 84379...
which is the best option for dialed number
Try to eliminate a dot from DP 1007 and it should be the best option
Let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
a ....sorry ....i mistake
the right is 843791..  2dot...
Nadeem Ahmed
First of all, you having overlapping dial-peer which can cause this issue this is not at all recommended to configured in such way .either Set the preference or set inter-digit time out . also you apply the configuration as suggested carlo too.
br,
Nadeem
Br, Nadeem Please rate all useful post.
