Incoming call failures - CALL_ERROR_INFORMATIONAL; Call Id Is Invalid=-1
Rahlekk
Hey all.
I'm trying to finish up configuration on a Cisco 2901 voice gateway connected to a few POTS lines.
Outbound dialing works fine, I see the calls hit the router and they go out just fine. However, for inbound calls, they ring a few times and then go fast busy, and I see this:
2901#sh call active voice compact
 <callID>  A/O FAX T<sec> Codec       type        Peer Address       IP R<ip>:<udp>
Total call-legs: 1
       100 ANS     T0     None        TELE        P
They hit the router but the router doesn't seem to send them anywhere. I've attached my voice gateway configuration as well as my debug voice ccapi all logs.
Gregory Brunn
Can you do a debug dial peer
Your are plaring your FXO to 2930  which dial peer sends this to CUCM?
Am i missing it
You have a pattern for 23XX not 29XX
dial-peer voice 2300 voip
preference 1
destination-pattern 23..
session target ipv4:172.29.21.11
voice-class codec 10
voice-class h323 10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 2301 voip
preference 2
session target ipv4:172.29.36.11
voice-class h323 10
