Incoming call issue in srst
waqas sardar
I am facing issue of incoming call is landing on gateway, but its not going to cisco ip phone in Sip srst mode.
Show Running
deb isdn q931
sh voice regist   t all
Building configuration...
Current configuration : 3405 bytes
! Last configuration change at 13:05:12 UTC Wed Mar 20 2013 by cisco
! NVRAM config last updated at 11:47:53 UTC Wed Mar 20 2013 by cisco
version 15.0
hostname SHJ-VG
boot-start-marker
boot system flash c2900-universalk9-mz.SPA.150-1.M9.bin
boot-end-marker
card type e1 0 0
enable secret 5 $1$J7pC$gty.40SmKhsNRDend51jN.
aaa new-model
aaa authentication login default local
aaa session-id common
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
no ipv6 cef
ip source-route
ip cef
isdn switch-type primary-4ess
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  registrar server expires max 600 min 60
voice register global
max-dn 200
max-pool 1
voice register pool  1
translation-profile incoming DID
id network 192.168.66.0 mask 255.255.255.0
preference 1
proxy 192.168.66.1 monitor probe icmp-ping
voice translation-rule 1
rule 1 /^50\(.....\)/ /\1/
voice translation-profile DID
translate called 1
license udi pid CISCO2921/K9 sn FTX1544ALRR
hw-module pvdm 0/0
redundancy
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-10,16 service mgcp
controller E1 0/0/1
description "CONNECTED TO LAN"
ip address 192.168.69.38 255.255.255.224
duplex auto
speed auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed 1000
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
router ospf 1
log-adjacency-changes
area 502 stub
network 192.168.69.38 0.0.0.0 area 502
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
call fallback active
voice-port 0/0/0:15
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/0/2
voice-port 1/0/3
voice-port 1/0/4
voice-port 1/0/5
voice-port 1/0/6
voice-port 1/0/7
ccm-manager fallback-mgcp
ccm-manager redundant-host 10.51.0.11 10.61.0.10
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server 10.51.0.10
mgcp
mgcp call-agent 10.51.0.10 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-ban
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 nsf 000000
no mgcp fax-relay sg3-to-g3
mgcp profile default
dial-peer voice 11 pots
incoming called-number .
direct-inward-dial
dial-peer voice 10 pots
destination-pattern 9T
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
SHJ-VG#     ter mon
SHJ-VG#deb isdn q931
debug isdn q931 is  ON.
SHJ-VG#
SHJ-VG#
SHJ-VG#
SHJ-VG#
Mar 20 13:08:51.535: ISDN Se0/0/0:15 Q931: RX <- SETUP pd = 8  callref = 0x1EDC
Sending Complete
Bearer Capability i = 0x8090A3
  Standard = CCITT
  Transfer Capability = Speech
  Transfer Mode = Circuit
  Transfer Rate = 64 kbit/s
Channel ID i = 0xA18384
  Preferred, Channel 4
Calling Party Number i = 0x2181, '024177097'
  Plan:ISDN, Type:National
Called Party Number i = 0xC1, '5044722'
  Plan:ISDN, Type:Subscriber(local)
Mar 20 13:08:51.547: ISDN Se0/0/0:15 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x9EDC
Cause i = 0x809B - Destination out of order
SHJ-VG#
SHJ-VG#
SHJ-VG#
SHJ-VG#sh voice regist   t all
VOICE REGISTER GLOBAL
CONFIG [Version=7.1]
  Version 7.1
  Mode is srst
  Max-pool is 1
  Max-dn is 200
  Outbound-proxy is enabled and will use global configured value
  timeout interdigit 10
  network-locale[0] US    (This is the default network locale for this box)
  network-locale[1] US
  network-locale[2] US
  network-locale[3] US
  network-locale[4] US
  user-locale[0] US    (This is the default user locale for this box)
  user-locale[1] US
  user-locale[2] US
  user-locale[3] US
  user-locale[4] US
VOICE REGISTER DN
VOICE REGISTER POOL
Pool Tag 1
Config:
  Network address is 192.168.66.0, Mask is 255.255.255.0
  Proxy Ip address is 192.168.66.1
  Default preference is 1
  DTMF Relay is disabled
  kpml signal is enabled
Dialpeers created:
dial-peer voice 40005 voip
preference 1
destination-pattern 44722
redirect ip2ip
session target ipv4:192.168.66.28:5060
session protocol sipv2
digit collect kpml
  after-hours-exempt   FALSE
redirect ip2ip
session target ipv4:192.168.66.1:5060
digit collect kpml
monitor probe icmp-ping 192.168.66.1
Statistics:
  Active registrations  : 1
  Total SIP phones registered: 1
  Total Registration Statistics
    Registration requests  : 27
    Registration success   : 27
    Registration failed    : 0
    unRegister requests    : 26
    unRegister success     : 26
    unRegister failed      : 0
5 Replies 5
iptuser55
Level 6
Level 6
I would check what the phones are register as when in SRST mode as the DN may be different ? show sip-ua status registrar
Anas Abueideh
Level 9
Level 9
what kind of phones you have ? are they SCCP or SIP ? Did you assign SRST reference in the device pool?
Anas
please rate if it is helpful
Hi  Anas,
Sorry these are Sip phones .
yes we have configured SRST reference in device pool.
change your max-pool to 27 and check
max-dn 200
max-pool 1
Anas
HI
I hope to check my below configuration which i used before andit was working fine.
your config
preference 1
my config
id mac "type mac addressesof Cisco IP phone to check"
number 1 xxxxx "Ext for example"
codec
g711ulaw
Thank you
please rate if this will help.
