07-07-2017 07:04 AM - edited 03-17-2019 10:43 AM
Dear All
we have an issue with fxo ports
our deployment is
CUCM ----H.323 GW with FXO
Outgoing calls works fine ,but no incoming calls success .
This Gateway in Tanzania
kindly find attached
run config and debug commands
07-07-2017 07:39 AM
Check the codec on your SIP trunk on CUCM. VOIP dial peers use g.729 by default. You can change the dial peer with "codec g711ulaw" for example. Or change the region setting for the region assigned to the SIP trunk.
Brandon
07-07-2017 11:31 AM
Could you please provide as debug h245 asn1 and debug h225 asn1. if possible call manager traces for the particular call.
07-14-2017 11:07 AM
Try to add a new dial-peer
dial-peer voice 100 pots
incoming called-number .
direct-inward-dial
Then try........
