Incoming call only after outgoing call?
ZlatkoBN1
When I am calling to numbers which is to be reached accross H.323 Voice Gateway (1751-V, c1700-ipvoice-mz.123-7.XR3.bin) all is OK. But, incoming call on that gateway can be placed only one time after making outgoing call on that gateway.
IP phone - CCM - Voice Gateway - ISDN works OK
PSTN - voice gateway - CCM - IP phone can be placed only one time if previously make outgoing call.
For connection to Telco Voice Gateway (with VIC-2B-NT/TE) use ISDN BRI.
I have read about this problem, but now I can't to find now. Can anybody suggest me any idea about this problem?
Thanks!
paolo bevilacqua
Hi, you should upgrade IOS first, chances are, it is be corrected in a later release.
Not applicable
While you are calling outside number can you provid ethe details of these show commands?
show voice call sum
show voice port sum
paolo bevilacqua
After upgrading IOS problem is solved.
