04-03-2018 01:26 PM - edited 03-17-2019 12:33 PM
I have 1 number that users call in on and have 2 backend servers that connect via SIP Trunks. I would like the calls to rotate between two servers so that they are used equally.
First I created a Translation rule to route to a Hunt Pilot/List that included 2 CTI Numbers that routed to the Extension for both of the SIP Trunks. However, it seems you cannot use CTI numbers in Hunt List that are forwarding to the SIP.
Any recommendations on how I could do this?
Solved! Go to Solution.
04-03-2018 06:59 PM
04-03-2018 02:53 PM
If you want calls to be distributed to different destinations you use SIP trunks to communicate with, you use a single DN, but configure that in the route group/route list.
04-03-2018 06:59 PM
08-01-2018 03:30 PM
I have 2 trunks in a circular pattern. At times the one trunk will need to be down for maintenance. When calling in every other call is a long silence with a continuous ring. The other half function as normal. Is there any way I can correct this so it uses the trunk that up?
08-01-2018 03:38 PM
When calling in
If you mean calls from the PSTN inbound to your CUCM, that beyond your control, that's something you'd need to discuss with the telco.
08-01-2018 03:53 PM
Users call in and get one of 2 trunks in a circular pattern. If one of those trunks goes down I get a long silence and a continuous ring. The trunks are connected to an internal IVR which sometimes need to be updated, restarted, etc. How do I direct the calls to go to the IVR that is online and skip the other trunk.
08-01-2018 04:01 PM
What is the exact call flow that you have?
08-01-2018 04:15 PM
DID > Extension > Route Pattern > Route List > Route Group (Circular) > SIP Trunk 1(IVR1)or 2(IVR2) > Destination
08-01-2018 05:10 PM
I created a SIP Profile with options ping enabled and assigned the profile to both trunks. Will test and let you know.
