Incoming call to SIP Trunk Circular Pattern
JimBCC
I have 1 number that users call in on and have 2 backend servers that connect via SIP Trunks. I would like the calls to rotate between two servers so that they are used equally.
First I created a Translation rule to route to a Hunt Pilot/List that included 2 CTI Numbers that routed to the Extension for both of the SIP Trunks. However, it seems you cannot use CTI numbers in Hunt List that are forwarding to the SIP.
Any recommendations on how I could do this?
Aeby Vinod
Level 3
Level 3
You can create a route pattern with the specific number and assign a route list to it. On the route list assign a route group having both the SIP Trunks and choose the distribution algorithm on the route group to be circular.
So call flow will be:
IP Phone > Route Pattern > Route List > Route Group (Circular) > SIP Trunk 1 > Destination
SIP Trunk 2 > Destination
Please rate if you find this helpful.
Aeby
Aeby
8 Replies 8
Jaime Valencia
If you want calls to be distributed to different destinations you use SIP trunks to communicate with, you use a single DN, but configure that in the route group/route list.
java
if this helps, please rate
Aeby Vinod
Level 3
Level 3
Aeby
Aeby
I have 2 trunks in a circular pattern. At times the one trunk will need to be down for maintenance. When calling in every other call is a long silence with a continuous ring. The other half function as normal. Is there any way I can correct this so it uses the trunk that up?
When calling in
If you mean calls from the PSTN inbound to your CUCM, that beyond your control, that's something you'd need to discuss with the telco.
java
Users call in and get one of 2 trunks in a circular pattern. If one of those trunks goes down I get a long silence and a continuous ring. The trunks are connected to an internal IVR which sometimes need to be updated, restarted, etc. How do I direct the calls to go to the IVR that is online and skip the other trunk.
What is the exact call flow that you have?
java
DID > Extension > Route Pattern > Route List > Route Group (Circular) > SIP Trunk 1(IVR1)or 2(IVR2) > Destination
I created a SIP Profile with options ping enabled and assigned the profile to both trunks. Will test and let you know.
https://community.cisco.com/t5/collaboration-voice-and-video/how-to-enable-sip-options-ping-feature-on-a-sip-trunk/ta-p/3160559
