01-13-2019 07:42 AM - edited 03-17-2019 01:55 PM
what does it means " incoming called-number ."
What if we add incoming called-number .and destination pattern together like below
dial-peer voice 10 voip
preference 9
destination-pattern 36417...
voice-class codec 1
session target ipv4:192.168.2.100
dtmf-relay h245-alphanumeric
no vad
01-13-2019 07:56 AM
You may need to read this:
However your question may be answered on the following post
Hope this helps,
George
01-13-2019 09:51 AM
01-20-2019 10:50 AM - edited 01-20-2019 11:26 AM
" For incoming calls incoming called number takes precedence over destination
pattern in matching order "
Incoming calls means calls from the pstn ?
" For outgoing calls incoming called-number is ignored and only destination
pattern is used "
outgoing calls means from the gateway to cucm ?
01-20-2019 12:22 PM
"Outgoing" means from the perspective of the router. Each call that flows through a router has an inbound call leg and an outbound call leg. The inbound call leg is formed when inbound signaling is matched to a dial-peer (or to dial-peer 0), and the call is accepted by the router. Then the router analyzes the information in the inbound signaling, and based on its programming, selects an outbound dial-peer. The outbound call leg is formed when the router signals outbound based on the information in the outbound dial-peer.
So whether your PSTN circuit will be the incoming or outgoing call leg will depend on the origin/directionality of the call.
Maren
01-20-2019 09:25 PM
