12-02-2012 03:46 PM - edited 03-16-2019 02:30 PM
Hi every body.
I got a question
" incoming called -number .* " My book says . * means the one or more instances of preceding digit.
Suppose we have a dial peer as shown below:
dial peer 60001 pot
incoming called-number .*
Will ani 12345 match the above dial peer?
will ani 1111 match the above dial peer?
thanks and have a great day.
Solved! Go to Solution.
12-02-2012 07:01 PM
Hi Sarah,
Goodevening. Hope you had a great weekend :-)
AFAIK, the "incoming called-number" can be used to match all incoming calls, no matter what the called number is using all the three strings below:
a) . (single dot)
b) .* (single dot followed by asterisk)
c) .T (single dot followed by T)
Please refer to the command reference guide for this command which explains these strings:
http://www.cisco.com/en/US/docs/ios/voice/command/reference/vr_i1.html#wp1112139
For the dialpeer you had, it would match dnis (called number), not ani. If both those examples were dnis numbers, it would match both.
HTH.
Harmit.
12-02-2012 07:01 PM
Hi Sarah,
a) . (single dot)
HTH.
Harmit.
12-04-2012 03:22 AM
Thanks Harmit.
12-04-2012 06:56 AM
In addition to great post from Harmit (+5), I always use the single "." variant. Also, it is a good practice to have "incoming called-number ." on one POTS for each port or trunk group and one VOIP dial peer to control things like codec and other parameters.
HTH,
Chris
