Incoming calls fails on FXO PSTN
habouzyad
HI ,
I use PSTN line connected to the FXO card on the router.
I dont have a problem with the outgoing calls , but the incoming calls doesnt work.
Please, find in the attachement the following items:
1- show run of the router
2- debug voice ccapi in out ofe the external incoming call
Wolud someone help to resolve this problem
Thanks in advance
Cham
acampbell
Cham,
Looks like you are matching the default dial peer "0" for the incoming call
Try adding this :-
dial-peer voice 100 pots
description *** FOR INCOMING CALL MATCHING ***
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 101 pots
direct-inward-dial
port 0/0/1
dial-peer voice 102 pots
direct-inward-dial
port 0/0/2
dial-peer voice 103 pots
direct-inward-dial
port 0/0/3
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
