ā06-30-2016 06:03 PM - edited ā03-17-2019 07:25 AM
Dear
I am having issue on CME incoming calls from PSTN line . When calls is coming from pstn it's stuck up and busy tone
Kindly assist me to resolve the issue
Solved! Go to Solution.
ā06-30-2016 07:50 PM
Hi Mohamed,
As Manish requested, please do share the details to validate.
Prasana
ā06-30-2016 07:12 PM
What is the exact call flow? Does it involve PRI/FXO? Have you run any debugs for a failed call? Can you post all this info along with the running config.
Manish
ā07-01-2016 02:34 AM
Hi Manish
Thanks for you short response
The PSTN Line is Terminated with FXO Port.
Hi Mohamed,
Prasana
ā07-01-2016 04:21 AM
Hi Manish
Thanks for your short response.
The below is Voice Port Config
voice-port 0/0/1
trunk-group STC
supervisory disconnect dualtone mid-call
no battery-reversal
cptone BE
timeouts call-disconnect 120
timeouts wait-release 128
timing sup-disconnect 300
connection plar opx 5000
impedance complex2
caller-id enable
caller-id alerting line-reversal
caller-id alerting dsp-pre-allocate
