03-19-2019 05:38 PM - edited 03-19-2019 05:40 PM
Existing SIP SRST configuration (been working for years) that stopped working yesterday. No changes on our end and Provider says no problems on their end. I can see incoming calls reach the CUBE but they never get to the end user. This site is SRST so CUCM is remote and has been for a long time.
I tried everything to get this fixed to no avail so hoping someone can help me me out.
Topology: ISP SIP > CUBE > remote OFFICE > DMVPN > CUCM PUB/SUB
dial-peer voice 10 voip description inbound from ISP SIP session protocol sipv2 session target ipv4:172.16.1.134 incoming called-number 03761160.. voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay rtp-nte sip-info sip-kpml sip-notify codec g711alaw no vad ! dial-peer voice 20 voip description Inbound DIDs to CallManagerSub translation-profile incoming strip-0 destination-pattern 03761160.. session protocol sipv2 session target ipv4:10.192.11.21 incoming called-number . voice-class codec 8 voice-class sip bind control source-interface Tunnel1 voice-class sip bind media source-interface Tunnel1 dtmf-relay sip-kpml rtp-nte no vad ! dial-peer voice 30 voip description Inbound DIDs to CallManagerPub preference 1 destination-pattern 03761160.. session protocol sipv2 session target ipv4:10.192.11.20 voice-class codec 8 voice-class sip bind control source-interface Tunnel1 voice-class sip bind media source-interface Tunnel1 dtmf-relay rtp-nte no vad ! dial-peer voice 40 voip description Local to ITSP translation-profile outgoing PRE destination-pattern 9[2-9]....... session protocol sipv2 session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay rtp-nte codec g711alaw no vad ! dial-peer voice 50 voip description Long Distance to ITSP shutdown destination-pattern [04-9]........ session protocol sipv2 session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay rtp-nte codec g711alaw no vad ! dial-peer voice 60 voip description Emergency to ITSP destination-pattern 999 session protocol sipv2 session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay rtp-nte codec g711alaw no vad ! dial-peer voice 70 voip description Toll-Free to ITSP translation-profile outgoing PRE destination-pattern 9.T session protocol sipv2 session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay sip-kpml rtp-nte codec g711alaw no vad ! dial-peer voice 80 voip description Toll-Free-Translation to ITSP preference 1 shutdown destination-pattern [012-9].......T session protocol sipv2 session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay rtp-nte sip-info sip-kpml sip-notify codec g711alaw no vad ! dial-peer voice 90 voip description Jaring Mobile to ITSP shutdown destination-pattern [015].......... session protocol sipv2 session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay rtp-nte sip-info sip-kpml sip-notify codec g711alaw no vad ! dial-peer voice 100 voip description New Mobile to ITSP shutdown destination-pattern 011.......... session protocol sipv2 session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay rtp-nte sip-info sip-kpml sip-notify codec g711alaw no vad ! dial-peer voice 110 voip description US International to ITSP destination-pattern 00T session protocol sipv2 session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 dtmf-relay rtp-nte sip-info sip-kpml sip-notify codec g711alaw no vad ! dial-peer voice 120 voip description TEST to lTIME destination-pattern +1[2-9]......... session target ipv4:172.16.1.134 voice-class sip bind control source-interface GigabitEthernet0/2 voice-class sip bind media source-interface GigabitEthernet0/2 codec g711alaw
r2-si-cube#show log Syslog logging: enabled (37 messages dropped, 17 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled) No Active Message Discriminator. No Inactive Message Discriminator. Console logging: disabled Monitor logging: disabled Buffer logging: level debugging, 6355 messages logged, xml disabled, filtering disabled Exception Logging: size (4096 bytes) Count and timestamp logging messages: disabled Persistent logging: disabled No active filter modules. Trap logging: level debugging, 10385 message lines logged Logging Source-Interface: VRF Name: Log Buffer (10000000 bytes): 003291: *Mar 20 07:48:05.702: //-1/468DE93C80EE/CCAPI/cc_api_display_ie_subfields: cc_api_call_setup_ind_common: cisco-username=14089869999 ----- ccCallInfo IE subfields ----- cisco-ani=sip:14089869999@172.16.1.134;pstn-params=9084818088 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest=sip:0376116060@10.205.3.26:5060;bgid=3000;bgt=private cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=-1 cisco-rdnsi=-1 cisco-redirectreason=-1 fwd_final_type =0 final_redirectNumber = hunt_group_timeout =0 003292: *Mar 20 07:48:05.702: //-1/468DE93C80EE/CCAPI/cc_api_call_setup_ind_common: Interface=0x3E8DA1B4, Call Info( Calling Number=sip:14089869999@172.16.1.134;pstn-params=9084818088,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=sip:0376116060@10.205.3.26:5060;bgid=3000;bgt=private(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Incoming Dial-peer=10, Progress Indication=NULL(0), Calling IE Present=TRUE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=81 003293: *Mar 20 07:48:05.706: //-1/468DE93C80EE/CCAPI/ccCheckClipClir: In: Calling Number=sip:14089869999@172.16.1.134;pstn-params=9084818088(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 003294: *Mar 20 07:48:05.706: //-1/468DE93C80EE/CCAPI/ccCheckClipClir: Out: Calling Number=sip:14089869999@172.16.1.134;pstn-params=9084818088(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 003295: *Mar 20 07:48:05.706: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 003296: *Mar 20 07:48:05.706: :cc_get_feature_vsa malloc success 003297: *Mar 20 07:48:05.706: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 003298: *Mar 20 07:48:05.706: cc_get_feature_vsa count is 20 003299: *Mar 20 07:48:05.706: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 003300: *Mar 20 07:48:05.706: :FEATURE_VSA attributes are: feature_name:0,feature_time:972142712,feature_id:80 003301: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/cc_api_call_setup_ind_common: Set Up Event Sent; Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=(TON=Unknown, NPI=Unknown)) 003302: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/cc_process_call_setup_ind: Event=0x3F3B1440 003303: *Mar 20 07:48:05.706: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search: Try with the demoted called number 0376116060 003304: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/ccCallSetContext: Context=0x26D7F47C 003305: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/cc_process_call_setup_ind: >>>>CCAPI handed cid 81 with tag 10 to app "_ManagedAppProcess_Default" 003306: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/ccCallProceeding: Progress Indication=NULL(0) 003307: *Mar 20 07:48:05.706: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer: mempool not found from usrContainer(3D568260) 003308: *Mar 20 07:48:05.706: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer: Mempool(25606464) created in usrContainer(3D568260) 003309: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/ccCallSetupRequest: Destination=, Calling IE Present=TRUE, Mode=0, Outgoing Dial-peer=20, Params=0x26D80A74, Progress Indication=NULL(0) 003310: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/ccCheckClipClir: In: Calling Number=sip:14089869999@172.16.1.134;pstn-params=9084818088(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 003311: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/ccCheckClipClir: Out: Calling Number=sip:14089869999@172.16.1.134;pstn-params=9084818088(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed) 003312: *Mar 20 07:48:05.706: //81/468DE93C80EE/CCAPI/ccCallSetupRequest: Destination Pattern=03761160.., Called Number=0376116060, Digit Strip=FALSE 003313: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/ccCallSetupRequest: Calling Number=sip:14089869999@172.16.1.134;pstn-params=9084818088(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=0376116060(TON=Unknown, NPI=Unknown), Redirect Number=, Display Info= Account Number=14089869999, Final Destination Flag=TRUE, Guid=468DE93C-49D8-11E9-80EE-88FB66AAD26F, Outgoing Dial-peer=20 003314: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/cc_api_display_ie_subfields: ccCallSetupRequest: cisco-username=14089869999 ----- ccCallInfo IE subfields ----- cisco-ani=sip:14089869999@172.16.1.134;pstn-params=9084818088 cisco-anitype=0 cisco-aniplan=0 cisco-anipi=0 cisco-anisi=0 dest=0376116060 cisco-desttype=0 cisco-destplan=0 cisco-rdie=FFFFFFFF cisco-rdn= cisco-rdntype=0 cisco-rdnplan=0 cisco-rdnpi=-1 cisco-rdnsi=-1 cisco-redirectreason=-1 fwd_final_type =0 final_redirectNumber = hunt_group_timeout =0 003315: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/ccIFCallSetupRequestPrivate: Interface=0x3E8DA1B4, Interface Type=3, Destination=, Mode=0x0, Call Params(Calling Number=sip:14089869999@172.16.1.134;pstn-params=9084818088,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed), Called Number=0376116060(TON=Unknown, NPI=Unknown), Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20, Call Count On=FALSE, Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=) 003316: *Mar 20 07:48:05.710: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 003317: *Mar 20 07:48:05.710: :cc_get_feature_vsa malloc success 003318: *Mar 20 07:48:05.710: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 003319: *Mar 20 07:48:05.710: cc_get_feature_vsa count is 21 003320: *Mar 20 07:48:05.710: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa: 003321: *Mar 20 07:48:05.710: :FEATURE_VSA attributes are: feature_name:0,feature_time:972143160,feature_id:81 003322: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/cc_api_event_indication: Event=101, Call Id=81 003323: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/cc_api_event_indication: Event Is Sent To Conferenced SPI(s) Directly 003324: *Mar 20 07:48:05.710: //82/468DE93C80EE/CCAPI/ccIFCallSetupRequestPrivate: SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1 003325: *Mar 20 07:48:05.710: //82/468DE93C80EE/CCAPI/ccCallSetContext: Context=0x26D80A24 003326: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/ccSaveDialpeerTag: Outgoing Dial-peer=20 003327: *Mar 20 07:48:05.710: //82/468DE93C80EE/CCAPI/ccGetMediaClassTag: media class tag 0 003328: *Mar 20 07:48:05.710: //82/468DE93C80EE/CCAPI/ccSetMediaclassIp2ipTags: media class tags set: NR 0, ASP 0 003329: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/ccGetMediaClassTag: media class tag 0 003330: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/ccSetMediaclassIp2ipTags: media class tags set: NR 0, ASP 0 003331: *Mar 20 07:48:05.710: //82/468DE93C80EE/CCAPI/ccGet_xc_nr_asp_info: media class tags: NR 0, ASP 0 003332: *Mar 20 07:48:05.710: //81/468DE93C80EE/CCAPI/ccGet_xc_nr_asp_info: media class tags: NR 0, ASP 0 003333: *Mar 20 07:48:05.710: //-1/xxxxxxxxxxxx/CCAPI/cc_is_cng_fax_detect_active: Call Id 81 003334: *Mar 20 07:48:05.710: //82/468DE93C80EE/CCAPI/cc_api_event_indication: Event=194, Call Id=82 003335: *Mar 20 07:48:05.710: //82/468DE93C80EE/CCAPI/cc_api_event_indication: Event Is Sent To Conferenced SPI(s) Directly 003336: *Mar 20 07:48:05.710: //81/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 003337: *Mar 20 07:48:05.710: cc_api_get_xcode_stream : 4982 003338: *Mar 20 07:48:05.710: //82/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 003339: *Mar 20 07:48:05.710: cc_api_get_xcode_stream : 4982 003340: *Mar 20 07:48:05.710: //81/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 003341: *Mar 20 07:48:05.710: cc_api_get_xcode_stream : 4982 003342: *Mar 20 07:48:05.710: //81/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 003343: *Mar 20 07:48:05.710: cc_api_get_xcode_stream : 4982 003344: *Mar 20 07:48:05.710: //82/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 003345: *Mar 20 07:48:05.710: cc_api_get_xcode_stream : 4982 003346: *Mar 20 07:48:05.710: //81/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 003347: *Mar 20 07:48:05.710: cc_api_get_xcode_stream : 4982 003348: *Mar 20 07:48:05.710: //82/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 003349: *Mar 20 07:48:05.710: cc_api_get_xcode_stream : 4982 003350: *Mar 20 07:48:05.710: //82/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream: 003351: *Mar 20 07:48:05.710: cc_api_get_xcode_stream : 4982 003352: *Mar 20 07:48:05.714: //82/468DE93C80EE/CCAPI/cc_api_call_proceeding: Interface=0x3E8DA1B4, Progress Indication=NULL(0)
03-20-2019 08:43 AM
If I'm reading this right
DP 10 = Incoming call from ITSP
DP 20 = From CUBE to CUCM
DP 30 = From CUBE to CUCM
I see a two problems with DP 20, you have a translation-profile there and you are also mixing called-number with destination-pattern. I believe the configuration of DP 30 is correct, so try disabling DP20 either shutting it down or increasing the preference and test again.
Rolando A. Valenzuela
