Showing results forĀ
Search instead forĀ
Did you mean:Ā
INCOMING CALLS NOT WORKING
mukthar786
Two Cisco Server's with CUCM11.5 & ISR 4321( E1 Modules)
for configuring 30 PRI/E1 which Trunk type has to be used SIP TRUNK / H.225
IF I Select SIP TRUNK with Route patterns  incoming calls not working for outgoings no problem.
2 Accepted Solutions
From your first post it sounds like you have a SIP trunk setup in CUCM targetting the Gateway, is that correct?
If so, you have a few configuration additions to make, as shown below. That is also in addition to the advice Nithin provided above.
I saw that you have a voice translation rule configured, but not applied anywhere. Not a big deal if the caller ID delivered from your carrier matches your extension range, but if it doesn't then you need a translation applied somewhere (voice-port, dial-peer or do it in CUCM).
- Create an inbound dial-peer which allows calls to match this on the via header. e.g:
voice-class uri CUCM SIP
 host ipv4:1.2.3.4
 host ipv4:5.6.7.8
- Create a server-group to allow calls from the PSTN to match an outbound dial-peer to CUCM:
voice-class server-group 100
 description ***CUCM Cluster***
 ipv4: 1.2.3.4
 ipv4: 5.6.7.8 preference 1
- Add an incoming dial-peer to match on the via header of the CUCM IP address:
dial-peer voice 100 voip
 description Incoming to CUBE from CUCM
 session protocol sipv2
 incoming uri via CUCM
 voice-class codec 1
 voice-class sip bind control source-interface GigabitEthernet0/0/0
 voice-class sip bind media source-interface GigabitEthernet0/0/0
 dtmf-relay rtp-nte
 no vad
- Add an outbound dial-peer facing CUCM on your gateway:
dial-peer voice 200 voip
 description Outgoing from CUBE to CUCM
 session server-group 100
 voice-class codec 1
 voice-class sip options-keepalive
 dtmf-relay rtp-nte
 no vad
 Also configure "forward-digits default" under dial-peer 1000. The "forward-digits 0" config is not needed there.
Here is a sample config Where incoming are through PRI and SIP trunk between CUCM and gateway
isdn switch-type primary-net5
trunk group VG-PRI-TRK
max-calls voice 60
voice service voip
ip address trusted list
ipv4 XX.XX.XX.XX
ipv4 XX.XX.XX.XX
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
trace
sip
voice class uri 1 sip
host ipv4:XX.XX.XX.XX
voice class uri 2 sip
voice class codec 1
codec preference 1 g729r8
codec preference 2 g711ulaw
voice class server-group 1
ipv4 XX.XX.XX.XXpreference 1
ipv4 XX.XX.XX.XX preference 2
ipv4 XX.XX.XX.XX preference 1
voice class sip-options-keepalive 1
voice translation-rule 1
rule 1 /^22087\(...$\)/ /7\1/
voice translation-rule 2
rule 1 /^\(7...\)$/ /2208\1/
voice translation-profile IN
translate called 1
voice translation-profile OUT
translate calling 2
controller E1 0/1/0
clock source line primary
pri-group timeslots 1-31
trunk-group VG-PRI-TRK timeslots 1-31
controller E1 0/1/1
clock source line secondary
voice-port 0/1/0:15
translation-profile incoming IN
translation-profile outgoing OUT
voice-port 0/1/1:15
dial-peer voice 1 pots
description incoming calls from PSTN
incoming called-number .
direct-inward-dial
dial-peer voice 10 voip
description Outgoing calls to CUCM
destination-pattern ^74..$
voice-class codec 1
dtmf-relay rtp-nte sip-notify
dial-peer voice 20 pots
trunkgroup VG-PRI-TRK
description Local calls to PSTN
destination-pattern 92.......
forward-digits 8
dial-peer voice 21 pots
description Mobile calls to PSTN
destination-pattern 9[789].......
forward-digits 8
dial-peer voice 22 pots
description International calls to PSTN
destination-pattern 900T
prefix 00
dial-peer voice 23 pots
description Service calls to PSTN
destination-pattern 91...
forward-digits 4
dial-peer voice 24 pots
description Civil Defense calls to PSTN
destination-pattern 99999
forward-digits 4
Response Signature
5 Replies 5
for configuring 30 PRI/E1 which Trunk type has to be used SIP TRUNK / H.225:- its recommended to use SIP trunk as Ciscois  removing support of H323 from latest ios versions.
IF I Select SIP TRUNK with Route patterns, that is for outgoing calls and not for  incoming.
For incoming you must check the below things.
Dial-peers on the gateway
Voice translation from DID to your extensions.
Inbound CSS on trunk
if you share the voice gateway configurations we might be able to help you quickly.
Response Signature
Gateway file attached
 host ipv4:1.2.3.4
 host ipv4:5.6.7.8
 ipv4: 1.2.3.4
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
with provider we have 30 Channel  PRI connected to E1 module of ISR 4321 Router.
max-calls voice 60
voice service voip
ipv4 XX.XX.XX.XX
ipv4 XX.XX.XX.XX
trace
sip
voice class codec 1
translate called 1
translate calling 2
controller E1 0/1/0
controller E1 0/1/1
voice-port 0/1/0:15
voice-port 0/1/1:15
direct-inward-dial
voice-class codec 1
forward-digits 8
forward-digits 8
prefix 00
forward-digits 4
forward-digits 4
Response Signature
