ā03-19-2013 08:04 PM - edited ā03-16-2019 04:20 PM
I have CME 8.6 which works fine for outgoing/incoming calls to/from PSTN by means of sip trunk, also is posible to call to other CME in remote site via h323 trunk.
The only problem is with AVAYA h323 trunk, I can call from CME to avaya extension but I can no received call from avaya extension.
I attach some debug lines, I found the line:
Categorized cause:65, category:278
I don't know why I can complete incoming calls
regards
ā03-20-2013 06:13 AM
Can you post your config and "debug voice dialpeer" and identify what you are dialing?
It does not look like you have incoming dial peer defined to match the call and might be using default dial peer 0 resulting in codec mismatch, etc. What IOS version are you using?
HTH,
Chris
ā03-20-2013 06:26 AM
Hi Chris,
Hi Chris,
Thanks for your response.
I attach sh run of CME in the main post. IOS version is c2900-universalk9-mz.SPA.151-4.M5.bin (CME 8.6).
from avaya extension is dialed 6300 (cme extension) , from CME to avaya extension two dial-peers are defined as shown in sh run.
the debug voice dialpeer info I'll get as soon as I got to office.
regards
ā03-20-2013 06:29 AM
I don't see the attachment, in either case make sure your toll-fraud prevention is not blocking the call. Also, post a "debug voice ccapi inout" and "debug h225 asn1", let us know the IP address of the Avaya system you expect the call to arrive from.
HTH,
Chris
ā03-20-2013 10:36 AM
Hi Chris,
thanks a lot for your time.
I attach debug file and sh run of cme you asked me. all IPs are included in toll-fraud prevention module.
the IP of avaya system is 172.24.46.10.
In debug file I can see avaya's extension number (2250) and cme extesion 6300, but I can't see ip of avaya system.
by another hand in debug file there is a line that show incoming dial-peer number (25) but in sh run that dial-peer correspond to incoming call
for trunk sip v2 between CME and sip provider (PSTN calls).
I hope this info can be useful
regards
ā03-20-2013 10:43 AM
Is this the full config, I see:
Incoming Dial-peer=25
yet, I dont see dial peer 25 in your config.
The IP address of Avaya is in Hex value
ip 'AC182E0A'
Chris
ā03-20-2013 11:03 AM
ā03-20-2013 11:06 AM
The inbound call is matching dial-peer 25 which is defined as SIP dial peer, hence the issue, you need build the H323 dial peer with more explicit incoming called-number statement to differentiate it from this dial peer.
HTH,
Chirs
ā03-20-2013 11:31 AM
Chris,
I defined the following dial-peer in cme
dial-peer voice 52 voip
destination-pattern 6300
session target ipv4:172.25.67.1
incoming called-number .
dtmf-relay h245-alphanumeric
no vad
but I still see dial-peer 25 in debug file, the call fails :-(
ā03-20-2013 11:36 AM
Correct, as both of you dial peers have overlapping incoming called-number, you need to differentiate them as they use different protocols. Incoming dial peers are first matched based on this statement, since they are both defined with "." they overlap.
Since the digits are dialed the same from SIP destinations and H323 destinations the easiest way would be to prefix a digit before sending it out and then stripping it to distinguish the call flow. For example you can prefix a digit, lets say 8 on Avaya before sending it to CME, then on CME build translation rule that strips it, then your dial peer 52 can have incoming called-number 8.... defined.
HTH, please rate all useful posts!
Chris
ā03-20-2013 11:43 AM
Hi Chris,
Thanks for this recomendation. I'm going to try it
what is weird is that another remote CME has the same config (just change extension number 62XX instead of 63XX)
and works fine for incoming calls form avaya system.
regards
ā03-20-2013 11:45 AM
Is the order of dial peers the same? I.e. is the SIP or H323 default inbound dial peer listed first in the config? You can play with that, but that may break your SIP connections, worth trying.
HTH,
Chris
ā03-20-2013 01:59 PM
Hi Chris,
It looks the issue was cleared.
I deleted dial-peer 25 from config, It seems incoming call were not affected; I can call from PSTN to CME extensions via sip trunk then I added the following dial-peer.
incoming called-number 63..
voice-class codec 3
no vad
I hope don't need more changes.
regards
