Incoming CLID through FXO port
wissamnad
Hi all,
I am getting a strange caller id on my 292 extension such as (22428, 22112, ...) whenever I try to call from the PSTN to the number associated to the voice port 0/0/1. I don't have any translations implemented. If the line provided from the Telco is directly connected to an analog telephone, the clid is correct but whenever its received by the router the caller id is showing 5 or 4 digits which doesnt make any sense.
I have the following config on a H323 voice gateway:
voice-port 0/0/1
trunk-group PSTN
connection plar opx 292
caller-id enable
dial-peer voice 1 pots
trunkgroup PSTN
description Calls to Fix land Lines
destination-pattern [2]........
dial-peer voice 2 pots
trunkgroup PSTN
description Mobile Calls
destination-pattern 9........
forward-digits all
dial-peer voice 5 pots
trunkgroup PSTN
description International Calls
destination-pattern 00T
forward-digits all
dial-peer voice 6 voip
destination-pattern 2..
session target ipv4:192.168.1.31
dial-peer voice 7 pots
incoming called-number .
paolo bevilacqua
Take "debug vpm signal" with "term mon" to see if CLID is right.
I already tried it, I called from a line 22XXXXXXX (which is another  FXO port on the same router) and it seems that some digits are being  stripped from the caller id (digits stripped randomly from the middle  and the end), please have a look, the calling number is in bold
Dec  6 21:27:54.757: htsp_timer_stop3 htsp_setup_req
Dec  6 21:27:54.757: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_HTSP_SETUP_REQ]fxols_onhook_setup
Dec  6 21:27:54.757: [0/0/1] set signal state = 0xC timestamp = 0
Dec  6 21:27:54.757: htsp_timer - 1300 msec
Dec  6 21:27:56.057: htsp_process_event: [0/0/1, FXOLS_WAIT_DIAL_TONE, E_HTSP_EVENT_TIMER]fxols_wait_dial_timer  htsp_dial
Dec  6 21:27:57.881: htsp_process_event: [0/0/1, FXOLS_WAIT_DIAL_DONE, E_DSP_DIALING_DONE]fxols_wait_dial_done htsp_progress
Dec  6 21:27:57.881: htsp_timer - 350 msec
Dec  6 21:27:57.881: htsp_call_bridged invoked
Dec  6 21:27:57.893: htsp_process_event: [0/0/1, FXOLS_WAIT_CUT_THRU, E_HTSP_VOICE_CUT_THROUGH]fxols_handle_cut_thru
Dec  6 21:27:57.893: htsp_timer_stop
Dec  6 21:27:59.021: htsp_process_event: [0/0/2, FXOLS_ONHOOK, E_DSP_SIG_0000]fxols_onhook_ringing
Dec  6 21:27:59.021: htsp_timer - 125 msec
Dec  6 21:27:59.149: htsp_process_event: [0/0/2, FXOLS_WAIT_RING_MIN, E_HTSP_EVENT_TIMER]fxols_wait_ring_min_timer
Dec  6 21:27:59.149: htsp_timer - 10000 msec
Dec  6 21:27:59.149: htsp_timer3 - 5600 msec
Dec  6 21:27:59.149: [0/0/2] htsp_start_caller_id_rx:BELLCORE
Dec  6 21:27:59.149: htsp_start_caller_id_rx create dsp_stream_manager
Dec  6 21:27:59.149: [0/0/2] htsp_dsm_create_success  returns 1
Dec  6 21:28:00.073: htsp_process_event: [0/0/2, FXOLS_RINGING, E_DSP_SIG_0100]
Dec  6 21:28:00.073: fxols_ringing_not
Dec  6 21:28:00.073: htsp_timer_stop
Dec  6 21:28:00.073: htsp_timer - 10000 msec
Dec  6 21:28:00.893: [0/0/2] htsp_dsm_feature_notify_cb  returns 2 id=DSM_FEATURE_SM_CALLERID_RX
Dec  6 21:28:00.893: htsp_process_event: [0/0/2, FXOLS_RINGING, E_HTSP_CALLERID_RX_DONE]
Dec  6 21:28:00.893: htsp_timer_stop
Dec  6 21:28:00.893: htsp_timer_stop3
Dec  6 21:28:00.893: [0/0/2] htsp_stop_caller_id_rx. message length 20htsp_setup_ind
Dec  6 21:28:00.893: [0/0/2] get_fxo_caller_id:Caller ID received. Message type=4 length=20 checksum=8F
Dec  6 21:28:00.893: [0/0/2] Caller ID String 04 11 B0 31 B0 32 32 B0 32 37 32 32 B6 34 32 B5 38 B0 31 8F
Dec  6 21:28:00.893: [0/0/2] get_fxo_caller_id calling num=224281 calling name= calling time=01/02 148:27
Dec  6 21:28:00.893: fxols_callerid_done: call being answered
Dec  6 21:28:00.897: [0/0/2] htsp_dsm_close_done
Dec  6 21:28:00.897: htsp_process_event: [0/0/2, FXOLS_WAIT_SETUP_ACK, E_HTSP_SETUP_ACK]
Dec  6 21:28:00.897: fxols_wait_setup_ack:
Dec  6 21:28:00.897: htsp_timer - 6000 msec
Dec  6 21:28:00.897: htsp_process_event: [0/0/2, FXOLS_PROCEEDING, E_HTSP_PROCEEDING]fxols_offhook_prochtsp_alert_notify
Dec   6 21:28:00.905: htsp_process_event: [0/0/2, FXOLS_PROCEEDING,  E_HTSP_ALERT]fxols_offhook_alerthtsp_call_service_msghtsp_call_service_msg  not EFXS (2)
Dec  6 21:28:03.981: htsp_timer_stop3
Dec  6 21:28:04.001: htsp_process_event: [0/0/1, FXOLS_OFFHOOK, E_HTSP_RELEASE_REQ]fxols_offhook_release
Dec  6 21:28:04.001: htsp_timer_stop
Dec  6 21:28:04.001: htsp_timer_stop2
Dec  6 21:28:04.001: htsp_timer_stop3
Dec  6 21:28:04.001: [0/0/1] set signal state = 0x4 timestamp = 0
Dec  6 21:28:04.001: htsp_timer - 2000 msec
Dec  6 21:28:04.013: htsp_process_event: [0/0/2, FXOLS_PROCEEDING, E_DSP_SIG_0000]fxols_proceed_ring
Dec  6 21:28:04.013: htsp_timer_stop
Dec  6 21:28:04.013: htsp_timer_stop2
Dec  6 21:28:04.945: htsp_process_event: [0/0/2, FXOLS_PROCEEDING, E_DSP_SIG_0100]fxols_proceed_clear
Dec  6 21:28:04.945: htsp_timer_stop2
Dec  6 21:28:04.945: htsp_timer - 6000 msec
Dec  6 21:28:06.001: htsp_process_event: [0/0/1, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Dec  6 21:28:06.001: htsp_process_event: [0/0/1, FXOLS_ONHOOK, E_DSP_SIG_0100]
AES-CME#
Dec  6 21:28:10.945: htsp_process_event: [0/0/2, FXOLS_PROCEEDING, E_HTSP_EVENT_TIMER]fxols_disc_confirm
Dec  6 21:28:10.945: htsp_timer_stop
Dec  6 21:28:10.945: htsp_timer_stop2
Dec  6 21:28:10.945: htsp_timer_stop3
Dec  6 21:28:10.945: htsp_process_event: [0/0/2, FXOLS_PROCEEDING, E_HTSP_RELEASE_REQ]fxols_offhook_release
Dec  6 21:28:10.945: [0/0/2] set signal state = 0x4 timestamp = 0
Dec  6 21:28:10.945: htsp_timer - 2000 msecu all
Dec  6 21:28:12.945: htsp_process_event: [0/0/2, FXOLS_GUARD_OUT, E_HTSP_EVENT_TIMER]fxols_guard_out_timeout
Dec  6 21:28:12.949: htsp_process_event: [0/0/2, FXOLS_ONHOOK, E_DSP_SIG_0100]
That seems bad, try updating IOS.
