Incoming Fax doesn't work
Support Albakom
Level 3
Level 3
we have an CUCM 8.5 connected via MGCP Gateway (Cisco 2911) to the PSTN. At the gateway there are 4 FXS ports configured with SCCP at the CUCM.
Now we have following. One fax machine in PSTN calls a fax machine which connected to one of the FXS ports.
This is the incoming debug isdn q931:
001674: Oct 12 14:11:03.578: ISDN BR0/2/1 Q931: RX <- SETUP pd = 8  callref = 0x01
        Bearer Capability i = 0x9090A3
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Progress Ind i = 0x8583 - Origination address is non-ISDN
        Calling Party Number i = 0x2181, 'XXX206XXX'
                Plan:ISDN, Type:National
        Called Party Number i = 0xC1, '1234408'
                Plan:ISDN, Type:Subscriber(local)
001675: Oct 12 14:11:03.586: ISDN BR0/2/1 Q931: TX -> SETUP_ACK pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
001676: Oct 12 14:11:03.670: ISDN BR0/2/1 Q931: RX <- INFORMATION pd = 8  callref = 0x01
        Called Party Number i = 0xC1, '4'
001677: Oct 12 14:11:03.670: ISDN BR0/2/1 Q931: TX -> DISCONNECT pd = 8  callref = 0x81
        Cause i = 0x8081 - Unallocated/unassigned number
001678: Oct 12 14:11:03.718: ISDN BR0/2/1 Q931: RX <- INFORMATION pd = 8  callref = 0x01
You see this call fails.
But now I called from another fax machine to the same number: It works:
Here is the debug isdn q931 output:
001699: Oct 12 14:13:06.881: ISDN BR0/2/0 Q931: RX <- SETUP pd = 8  callref = 0x01
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
        Calling Party Number i = 0x2183, '5555555'
        Called Party Number i = 0xC1, '123440844'
001700: Oct 12 14:13:06.889: ISDN BR0/2/0 Q931: TX -> CALL_PROC pd = 8  callref = 0x81
        Channel ID i = 0x89
                Exclusive, B1
001701: Oct 12 14:13:06.921: ISDN BR0/2/0 Q931: TX -> ALERTING pd = 8  callref = 0x81
        Progress Ind i = 0x8088 - In-band info or appropriate now available
001702: Oct 12 14:13:13.762: ISDN BR0/2/0 Q931: TX -> CONNECT pd = 8  callref = 0x81
001703: Oct 12 14:13:13.866: ISDN BR0/2/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x01
Can somebody say why the first call fails?
7 Replies 7
andypoore
This maybe a simple CSS partition issue, can you dial the fax internally from a phone?
acampbell
The 1st call is using over lap signalling from the PSTN.
Try adding this to your BRI interfaces
interface BRI 0/2/0
isdn overlap-receiving
isdn overlap-receiving T302 2000
interface BRI 0/2/1
Alex
Regards, Alex. Please rate useful posts.
Apologies didn't read the debug in it's entirety, Alex is probably right as the last two digits are sent after the call setup.
Andy,
I had a look on my lab set up.
Not sure if ISDN BRI is going to support the OVERLAP signalling under MGCP.
You may need to change to H323.
Alex
Hi Alex
Cisco have never been explicit on the matter, and this depends on which country this ISDN line is in, it looks suspiciously like it's not overlap sending of the digits from the Telco, but the T302 timing out before all the digits are received, I haven't used BRI in a long time but it's worth extending the timer via the command line and via the CUCM parameters, although again I'd have to check if changing it applies to both back hauled PRI and BRI.
Interested to see the results though.
isdn overlap-receiving T302 is already set to 5000 at all BRI interfaces and seems that it doesn't influence any if gateway configured with MGCP. I cant configure as H323 because we have just changed to MGCP while great trouble with ISDN channels with H323-configuration and overlap dialing.
Clutching at straws here now re the overlap receiving.
You could check the following service parameter.
Service Parameters --> Call Manager --> (DEVICE PRI & MGCP SECTION) -->
Overlap Receiving Flag for PRI.
Check this is set to TRUE
Other than changing back to H323 I can not think of how else to resolve this
Alex
