Hi everyone,
Hoping someone can please give me some pointers on where to look that could be manipulating external Caller-IDs as explained below on our CUCM 8.5 system?
We use 4 digit extensions internally that is made up of the last 4 digits of a user's DID (For example, user A's extension is 1234 and their DID is +61 2 9222 1234). As expected there is a translation pattern for our MGCP ISDN BRI gateways that translate 9222XXXX to the user's extension for incoming calls. This translation pattern has a transform for the calling party (00XXXXXXXXX), this is to add a 0 for an 'external line' and another 0 for the area code (2 becomes 0).
However we are seeing a situation where a Hong Kong based mobile calls in (E.g. +852 6111 4321) is translated to 00261114231. Obviously I can understand the 00 being added, after all it is what is set in the translation pattern. But I can't find where the "2" is being added nor the 852 being removed. Both the CDR records and a debug isdn q931 of the call both confirm the incoming caller ID is "85261114321".
Should the DNA tool be able to help finding what is transforming this? I was having difficulty getting it to correctly show incoming calls, great for outgoing calls...
