incoming is ok but outgoing is not working
techguy
Level 4
Level 4
One starnge problem, inbound calls are working but outbound calls from CUCM is not ok. PSTN Lines (FXO) are ok, as i have tested by analogue phone.
Following is the error.
QADHLNR0012901#sh voice iec description 1.1.278.5.88.0
    IEC Version: 1
    Entity: 1 (Gateway)
    Category: 278 (Media Negotiation Failure due to non-existing Codec)
    Subsystem: 5 (H323)
    Error: 88 (Fast codec mismatch)
    Diagnostic Code: 0
acampbell
Looks like you are failing due to H323 FastStart
On the CUCM page for the H323 gatway look at the OUTGOING CALLS section.
Have you selected "Enable Outbound Faststart" , have you selected the correct codec for Faststart.
You could just try unticking the Faststart and retest.
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
acampbell
Alex.
