incoming PSTN call not completing
I'm facing an strange problem with one of my clients
The got 2 separate PSTN line, one for Home and Office. Home phone setup to port 0/0/0 and office for 0/0/1
problem is Home phone just work fine, can do outbound and incoming, But office phone with same kind of configuration can make out going calls
but when there is a incoming call it rings the extension and if i pick up the phone to answer it just disconnect and immediately after its ring again and again until the external caller hangs-up. so basically cannot answer inbound calls to office phones.
any help please
shameer
Hi Shameer.
Please, post your config so we can give a look and try to move pstn line from port 1 to port 0 and see if the problem remains.
LMK.
Carlo
Please rate all helpful posts "The more you help the more you learn"
HI Carlo
thanks for your reply
config attached. please have a look. home line through 0/0/0 port working fine.
