01-14-2019 08:19 AM - edited 03-17-2019 01:56 PM
I have to provide an implementation to the following requirement and hoping that someone can provide a suggested working solution:
Calls from the SIP IPSP arrive as a full globalised E.164 format number from a CUBE gateway, i.e., \+44121etc . These numbers are to be sent out to a SIP trunk to a 3rd party Contact Center. I can only think to use a dial pattern with the SIP trunk in a RL/RG but cannot get this to work. I have tried translating the incoming \+44... number and then using the translated number as a route pattern against the RL/RG/SIP trunk but without success. I did try using the translated number as a DN on a phone and this proved the incoming and translation was ok.
My difficulty is understanding how I can send the incoming number to an outgoing SIP trunk.
UCM version 10.5
Thanks, John.
Solved! Go to Solution.
01-14-2019 09:08 AM
CUCM always uses best match routing for ANY call, you need to do as you mentioned, make sure that whatever you receive as the called party is matched by a route pattern so it simply goes out to other system.
If you want to do any digit manipulation to the called number with a TP, then make sure that TP has access to the RP with the transformed pattern, and that it's the best match in your dial plan.
01-14-2019 08:25 AM
01-14-2019 08:40 AM
Hi, thanks for your prompt reply.
I don't think the issue is with the CUBE config as this has been in use for a while now and we are using to receive from the PSTN and through to devices. As I previously stated, I can translate the incoming from the cube the translated number/s successfully connect to phone users. My difficulty is understanding if I can apply the numbers, either directly in the \+44 format, or, to translate the incoming e.164 and then apply this as a route pattern pointing to an outgoing RL/RG/SIP trunk.
For example, the received number from the cube to UCM is \+4412312346, this is translated to 12345. 12345 is set as a route pattern pointing to a sip trunk. Will this work in theory? I cannot think of another way where I can send an incoming number out to a SIP trunk.
01-14-2019 09:08 AM
