incoming voice-port digit strip
v-yelmene
Beginner
Beginner
Our Telco is sending us 10 digits on incoming calls. We would like to strip the first 6 digits, and just keep that last 4. We have 4 digit pattern internally. This is to make our voice-mail accessible from off campus. Does anyone have suggestions on how to do this? Here is what I was thinking might work;
translation-rule 1
rule 0 /^90774[5,6]..../ /..../
voice-port 0/0/0:23
translate calling-number 1
8 Replies 8
dezoconnor
Enthusiast
Enthusiast
If you're using an H.323 Gateway then that should work. If using MGCP then you would need to add a translation pattern on your communications manager.
You can test your translation-rule within the IOS prior to applying to the voice-port:
test voice translation-rule 1 cr
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
the rule you wrote won't work properly.
Please use:
rule 1 /^90774[56]/ //
Then, you can check the rule with "test voice translation-rule ".
I must be missing something. I'm getting an error msg.
msc-CME(config-translate)#rule 0 /^90774[5,6]/ //
Incorrect format for Translation Match Pattern
regular expression must be of the form ^(\^)?(\+)?([0-9,A-F.*%?#]+)$
Invalid match pattern string input /^90774[5,6]/
are you setting this up using voice translation-rule or the regular translation-rule command ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
regular translation-rule, I figure I can use voice version since I'm running 12.4?
hi, please use voice translations:
voice translation-rule 200
rule ..
voice translation-profile strip-to-did
translate called 200
voice-port x/y
translation-profile incoming strip-to-did
works great! thanks.
Good to know, please remember to rate useful posts!
Recognize Your Peers
