01-13-2016 10:54 PM - edited 03-17-2019 05:30 AM
Hi All,
i have 3 pstn line and 1 PRI line.
PSTN lines are connected using FXO ports.
when someone call to PSTN lines, the ip phone showing "Unknown Number" on the display, but when someone call PRI line the caller id is showing on the display..
voice-port 0/2/0
supervisory disconnect anytone
voice-port 0/2/1
ring number 3
connection plar 1889
caller-id enable
voice-port 0/2/2
ring number 3
caller-id enable
voice-port 0/2/3
ring number 3
caller-id enable
Please help me to resolve the issue.
01-14-2016 12:14 AM
Do you mean that caller phone display will be updated after dialing and show 'Unknown Number'. Also, please indicate whether your are using CUCM or CME? If CUCM, what protocol is used?
01-14-2016 01:13 AM
Caller display shows "Unknown Number" for incoming calls.
System version: 10.5.2.10000-5
H.323
01-14-2016 04:07 AM
These are FXO ports and you will not see caller id until you use correct CPTONE because the caller id method (DTMF, FSK etc) differs from country to country. By default CPTONE is US. Could you configure a CPTONE where the device is located? for ex; CPTONE IN..
try below config as well
voice-port <no.>
cptone BE
ring number 3
Run "debug vpm signal" on gateway and check if the gateway is receiving caller id .
