01-31-2012 10:48 PM - edited 03-16-2019 09:19 AM
Incorrect time on CME phone display
02-01-2012 12:15 AM
This is asked very often, have you tried searching before asking ?
02-01-2012 12:35 AM
Yes, I did creating cnf files under telephony services and then reset all phones. it doesnt worked out.
please assist me on this.
02-01-2012 02:24 AM
Maybe if you could take the time to read in full from the search results, as indicated above that would help you better.
02-01-2012 04:22 AM
under the telephony-service -
no create cnf-files
create cnf-files
Then reboot the individual phones
Whether above one is solution
02-01-2012 06:16 AM
Hi Karthikeyan,
Try the steps in this doc (pay special attention to Time Zone & phone model type)
Troubleshooting Incorrect Time Stamp on IP Phones in Cisco Unified CME
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/troubleshooting/guide/ts_time.html#wp1053981
Cheers!
Rob
02-01-2012 06:49 PM
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 2
sdspfarm tag 1 conferenceprof
sdspfarm tag 2 transcodeprof
conference hardware
no auto-reg-ephone
authentication credential admin cisco
max-ephones 110
max-dn 200
ip source-address 10.231.2.5 port 2000
max-redirect 20
service phone settingsAccess 1
timeouts ringing 60000
system message Nielsen - Chennai
url services http:///voiceview/common/login.do
url authentication http:///voiceview/authentication/authenticate.do
load 7942 SCCP42.8-4-2S.loads
load 7962 SCCP42.8-4-2S.loads
time-zone 39
time-format 24
date-format dd-mm-yy
voicemail 2100
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
hunt-group logout HLog
moh music-on-hold.au
web admin system name admin password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
secondary-dialtone 0
directory entry 1 555 name HelpDesk
create cnf-files version-stamp 7960 Feb 02 2012 07:56:02
I reset all phones ,. still am not getting correct timing on all phones. phone type : 7942
04-10-2013 05:06 AM
Did you ever get this resolved? If so what was the resolution?
04-10-2013 06:36 AM
Hello
you can configure as below and it will help
router# clock (type your date and time)
router (config)# clock tomezone (name) (x)
router(config)# clock summer-time
telephony -service
time-zone X
time-format 24
no Create-cnf
create-cnf
Thank you
please rate if this will help
03-10-2014 07:58 PM
09-23-2016 06:04 AM
I had the same problem too and I solved it as follow:
router(config)# clock timezone zone hours-offset
router(config-telephony)# clock time-zone number
