02-12-2013 10:39 AM - edited 03-16-2019 03:40 PM
I heard a rumour that the maximum RTT between servers in a UCM cluster had been increased to 160msec.
Does anyone have any confirmation of this and which version releases support it if true?
Chris
02-12-2013 11:09 AM
I haven't heard that, but the 9.x SRND shows 80ms RTT.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/9x/models.html#wp1044078
02-12-2013 11:13 AM
Hi Will,
That is what I found as well.
The rumour comes from someone inside Cisco so I thought I would pose the question here to try and get a definitive answer as it would help with some of my customers going forward if true.
Chris
02-12-2013 11:15 AM
In any case, roadmap questions as such cannot be discussed here, you want an official answer, you need to reach your SE or AM.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
02-12-2013 11:14 AM
Haven't heard anything around that, and neither the SRND nor the RNs for the latest versions mention anything like that.
java
