11-01-2009 03:30 PM - edited 03-15-2019 08:19 PM
hi everybody, we have a CCM 7.1.2.10000-16 version. Publisher and subscriber and recently it bought more licenses, because the time will expire in one week, i have upload new licenses in the publisher, my questions is: i need upload new licenses in both servers publisher and subscriber?, how to remove the old licenses or when the time expire it will enter the new license automaticly?, and how to configure publisher and subscriber redundant?, thank in advance for you help.
Solved! Go to Solution.
11-01-2009 04:22 PM
Hi there,
The license file gets uploaded to the Publisher (first node) only. You don't have to remove demo license, you may get a message stating that the demo license is being removed.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b02licfu.html
You can run the License Unit Report to confirm that both your nodes are licenses correctly.
To configure the Publisher and Subscriber redundancy you'll need to configure your Callmanager Groups correctly, see the following documents for more information.
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/srnd/7x/callpros.html#wp1043707
and
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/b02cmgrp.html
Paul
11-01-2009 04:22 PM
Hi there,
and
Paul
11-01-2009 04:30 PM
Hi Cristian,
Cisco Unified Communications Manager Releases 7.1(2) and 6.1(3) introduce these licensing enhancements.
Description
Cisco Unified Communications Manager Releases 7.1(2) and 6.1(3) identify the state of a license; that is, if it is missing, if it is a demo license, or if it is an uploaded license. In addition, Cisco Unified Communications Manager Administration warns you whether Cisco Unified Communications Manager currently operates with demo licenses, with an insufficient number of licenses, or with an incorrect software feature license.
GUI Changes
The following windows display the state of licenses in Cisco Unified Communications Manager
Administration:
- Cisco Unified Communications Manager currently operates with demo licenses, so upload the appropriate license files.
- Cisco Unified Communications Manager currently operates with an insufficient number of licenses, so upload additional license files.
- Cisco Unified Communications Manager does not currently use the correct software feature license. In this case, the Cisco CallManager service stops and does not start until you upload
the appropriate software version license and restart the Cisco CallManager service.
⢠License File Upload (System > Licensing > License File Upload)-This window displays a message
that uploading the license file removes the demo licenses for the feature.
Here is the procedure :)
The Node License Manager is the Publisher so it is the MAC Address that you provide for any licensing additions/requirements;
Licenses are generated for requested Cisco CallManager nodes (servers in a Cisco CallManager cluster - with seats) and the phones that are associated with those nodes.
Uploading a License File
Use the following procedure to upload a license file to the Cisco Unified Communications Manager server with the matching MAC address that is provided when a license file is requested. For information about obtaining a license file, see the "Obtaining a License File" section. The Cisco Unified Communications Manager server where the license file is loaded takes on the functionality of the license manager.
**Note: Upload the license file only on the first node of Cisco Unified Communications Manager cluster.
Procedure
Step 1 Choose System > Licensing > License File Upload.
The License File Upload window displays.
Step 2 The Existing License Files drop-down list box displays the license files that are already uploaded to the server.
Note To view the file content of any existing files, click View File.
Step 3 To choose a new license file to upload, click Upload License File.
The Upload File pop-up window displays.
Step 4 To upload to the server, click Browse to choose a license file.
Step 5 Click Upload.
After the upload process is complete, the Upload Result file displays.
Step 6 Click Close.
Step 7 In the License File Upload window, the status of the uploaded file displays.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_0_1/ccmcfg/b02licfu.html#wp1049590
The system overwrites the starter licence when you obtain and upload your permanent licenses.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/6_1_1/ccmcfg/b02licfu.html
Hope this helps!
Rob
