04-13-2020 11:55 PM
Good day, I have a Cisco unity connection cluster consists from one publisher and one subscriber, before when I installed the OVF of CUC, I choose the deployment configuration 1000 users-1 vCPU, but now due to the business needs, I have to increase the users capacity to 10,000 Users- 146GB disks, the question here is it possible to change the "deployment configuration " without reinstall the cluster ?
Note: CUC 11.5.1
Solved! Go to Solution.
04-14-2020 12:43 AM
04-14-2020 12:43 AM
04-14-2020 03:28 AM
Thank you Mohammed for your reply, it is a perfect solution but I would like to ask about the DRS backup in this case , can we store the DRS backup from CUC at the 1000 users OVA template then retrieve it after reinstall the new cluster (at 10,000 users OVA template ) ?
04-14-2020 07:44 AM
Nope, that's wrong, PCD does NOT support migration for CUC
And to answer OPs question, NO, you cannot just change the deployment model. It's is NOT supported to add vCPUs to CUC, the only option to do what you're asking is to install a new cluster with the OVA you need, and use DRS or COBRAS.
