07-05-2015 09:54 PM - edited 03-17-2019 03:32 AM
Hi All,
I have my dial-peers in placed and I can influence what Voice Port they can go out to when a certain route pattern is dialed, I used trunk group.
My question is, how can I influence the outbound call based on the Dialling Voip Internal Extension Number?
I tried creating a dial-pper with answer-address, but the call loops to the PLAR number configured on voice-port.
Config::
trunk group LOCAL-OUT
max-calls voice 10
max-retry 2
description *** LOCAL CALLS ***
hunt-scheme round-robin
voice-port 0/0/0
trunk-group LOCAL-OUT 1
supervisory disconnect dualtone mid-call
supervisory custom-cptone PHIL
timeouts call-disconnect 2
timeouts wait-release 5
timing hookflash-out 50
timing guard-out 1000
connection plar opx immediate 7600
shutdown
description *** OUTGOING - LOCAL OUT ***
bearer-cap Speech
voice class codec 711
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
dial-peer voice 1 pots
trunkgroup LOCAL-OUT
incoming called-number .
no digit-strip
forward-digits 4
dial-peer voice 2 voip
description incoming dial-peer PSTN to VOIP
session protocol sipv2
session target sip-server
session transport udp
voice-class codec 711
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte sip-notify
no vad
dial-peer voice 3 voip
description *** incoming INTERNAL ***
destination-pattern [1-7]...$
session target dns:cucm.internalserver.com
incoming called-number .%
no vad
Solved! Go to Solution.
07-06-2015 12:51 AM
Hi.
In you are on a CUCM deployment, you can use CSS with different partition and applying a prefix before the call is routed to the VG.
Once on the VG, you can strip the prefix within the pots dialpeer.
Carlo
07-06-2015 03:15 AM
Hi.
On dial-peer 8103 add huntstop command.
Carlo
07-06-2015 09:12 PM
Hi.
Try show dialplan number 795225777 hunt | i Match
Carlo
07-06-2015 12:51 AM
Hi.
Carlo
07-06-2015 03:07 AM
Hi Carlo,
This was a big help. Thank you!
But if I try to simulate that the line is busy by shutting down the port, the call still goes out to another voice-port with similar Route Pattern.
Ex:
Dial Peer that Matches the Route Pattern with a Prefix 79
dial-peer voice 8103 pots
port 0/0/0
description *** outgoing local calls ***
destination-pattern 79[2-9]......
forward-digits 7
When the port down, the outgoing call goes to this dial-peer:
dial-peer voice 103 pots
destination-pattern [2-9]......
no digit-strip
forward-digits 7
What config should I do so it will not go out to the 103 dial-peer?
I tried (from dialpeer 3) changing the Forward-digits 7 to forward-digits-all, but it still goes out to dialpeer 103.
Thanks!
07-06-2015 03:15 AM
Hi.
Carlo
07-06-2015 07:40 PM
Hi Carlo,
I tried putting a Huntstop for the DialPeer 8103, but when I ran the "sho dialplan number 795225777"
It still shows that the alternate dialpeer is Dialpeer103.
Thanks!
07-06-2015 09:12 PM
Hi.
Carlo
07-07-2015 12:24 AM
Hi.
Looking at your diaper I suggest to attach a # to the configured prefix on CUCM.
Than you can modify your dialpeer 8103 as follows:
port 0/0/0
destination-pattern #79[2-9]......
forward-digits 7
In this case the only possible match would be diaper 8103
Cheers
Carlo
07-07-2015 01:16 AM
Thanks Carlo,
It worked! :) I'll just put a # sign for the prefix, #79.
Now it's only routed to dialpeer8103
router-voice#sh dialplan num #795225777
Macro Exp.: #795225777
VoiceEncapPeer8103
07-07-2015 01:18 AM
You are welcome
Glad that worked ;)
07-07-2015 11:55 PM
Hi Carlo,
I have a dial-peer for IDD calls but I don't know how I can strip the #79 digits if I also need to influence it's outgoing route based on the internal extension. Since International call
dial-peer voice 200 pots
description *** outgoing IDD calls 1 ***
destination-pattern 00T
no digit-strip
forward-digits all
dial-peer voice 8200 pots
destination-pattern #7900T
no digit-strip
forward-digits all
Thanks!
07-08-2015 12:04 AM
Hi.
As I suggested, you need to create different partitions to include on new CSS that need to be assigned to dedicated users.
Than two route pattern for the same destination will exist but within different partitions and one with prefix attached and the other without any prefix.
Than pots dialpeers will strip specified digits if you don't add forward-digits all (as you did on your DP)
So try to remove forward digit keyword and add a different prefix for different destination,.
Eg
For local calls apply #77
For Long distance #78
For international #79
Carlo
07-09-2015 02:10 AM
Thanks Carlo,
Will try this, this weekend.
07-09-2015 10:46 PM
Grazie Carlo! :)
I tested it, and it worked!
dial-peer voice 8400 pots
description *** outgoing ANY LENGTH LOCAL & TOLL ***
huntstop
destination-pattern #8[^0][1-9].+
dial-peer voice 8500 pots
description *** outgoing ANY LENGTH NDD ***
huntstop
destination-pattern #80[2-9].+
dial-peer voice 8600 pots
description *** outgoing ANY LENGTH IDD ***
huntstop
destination-pattern #800[1-9].+
router-voice#sh dialplan num #80014185224646 | i Peer
VoiceEncapPeer8600
router-voice#sh dialplan num #887000 | i Peer
VoiceEncapPeer8400
router-voice#
router-voice#sh dialplan num #88878888 | i Peer
VoiceEncapPeer8400
router-voice#sh dialplan num #818662788187 | i Peer
VoiceEncapPeer8400
router-voice#sh dialplan num #80324958484 | i Peer
VoiceEncapPeer8500
Thanks so much!
Will just change it the Local, NDD, and IDD on the actual implem
#81
#82
#83
07-06-2015 08:37 PM
I tried also putting preference 1 with the huntstop, but it still sees the dial-peer 103
Thanks!
