10-04-2012 03:17 AM - edited 03-16-2019 01:31 PM
Good morning at all.
I've a little question about CUCM Calling-search-space.
I need th change a CSS name.
If I change the ccs name , all dependecy associate to this css will change the css or not?
for example
if I've one phone 1 are using the css (css- check) in callforward section and I' change the css name to css.new, this new css will be automatically assigned to the phone 1?
Thanks in advance
Giancarlo
Solved! Go to Solution.
10-04-2012 05:47 AM
Hi Giancarlo,
As always, Java is most correct here +5 Java-Man!
I thought this was an interesting question and I couldn't remember
if I'd ever actually tried this out. So I created a new CSS Called test_css
and applied it to a couple of test phones. I then went back to the CSS
config page and changed the name from test_css to test12_css and saved
the changes. Sure enough, as Java nicely noted the new name test12_css
had been applied to the phones that were using test_css before
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
10-04-2012 06:21 AM
The name of the CSS is just an attribute in the DB, the primary key (which ties it all together) doesn't change.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-04-2012 04:23 AM
Yes
10-04-2012 05:47 AM
Hi Giancarlo,
Cheers!
Rob
10-04-2012 06:21 AM
java
