326
Highlighted
Beginner
INSTALL CME 12 IN ROUTER ISR4321/K9
Hello
I have a router isr 4300 image isr4300-universalk9.16.06.05.SPA.bin and rommon isr4200_4300_rommon_169_1r_SPA.pkg. I have transfer the CME ver 12
CME-COMPLETE-FILESET-12.0.tar
cme-full-locale-12.0.tar
CME-GUI-12.0.tar
I used the command
Archive tar /xtract  ftp://192.168.1.30/CME-COMPLETE-FILESET-12.0.tar flash:
I am following same procedure for each .tar
The file has been extracted and it created the folder for each one. I reloaded however, when I go to config terminal, the command telephony-service is missing. What do I missing here?
flash.pngflash
CMDDIRECTORY.pngCMEDIR
Everyone's tags (1)
3 REPLIES 3
Hall of Fame Cisco Employee
Re: INSTALL CME 12 IN ROUTER ISR4321/K9
You do not have a UC license to use CME
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucme/admin/configuration/manual/cmeadm/cmeover.html#concept_779AC8A8399D4294AB699248BB5302F2
CME is already embedded in the IOS, you do not need to "install" CME.
java
if this helps, please rate
Rising star
For Activation evalutaion CUCME Featues use below command.
Router#show license all
StoreIndex: 1 Feature: uck9 Version: 1.0
License Type: EvalRightToUse
License State: Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
Period used: 0 minute 0 second
License Count: Non-Counted
License Priority: None
For Reference
• Use below commands to activate the evaluation uc feature
o license boot module <routermodel>  technology-package uck9
o reload
For Smart Licensing refer below
On the Unified CME router, you need to ensure that the call home feature is not disabled. Also, Smart Licensing feature should be enabled at the router using the CLI command license smart enable . Use the no form of the command to disable smart licensing. For more information on configuring Smart Licensing in your router, see Software Activation Configuration Guide, Cisco IOS Release 15M&T. Once the smart license is enabled and the router is not yet registered with CSSM, the device enters an evaluation period of 90 days.
You can register the router to CSSM with the token ID. To register the device (Unified CME router) with CSSM, use the CLI commandlicense smart register idtoken . For information on registering the device with CSSM, see Software Activation Configuration Guide.
*** Please rate helpful post; Mark "Accept as a Solution" if applicable
Haris
Hall of Fame Community Legend
No `tis not.  "Not In Use" because "EULA not accepted".  So this means the License isn't activated and cannot be used (until EULA is accepted).
conf t
 license accept end user agreement
end
wr
Content for Community-Ad
August's Community Spotlight Awards
